9 Pages «<45678>»
MWG build diary of IJN Akagi Options
#101 Posted : 05 December 2011 15:21:49
Loking great with the planking, keep up the good work mike Cool
Smuggler
#102 Posted : 05 December 2011 16:19:19
Lovely work with the plankingBigGrin
I smile because i have NO IDEA whats going on :)
#103 Posted : 06 December 2011 19:21:09
ISSUE 5 PARTS 17 TO 20
Continuing with the planking I am now doing the Port side, at this point the planks are fixed while they are wet,they will dry in shape then I can glue them in place.
Please exuse the gaps they will go when I fit them permanentlyBigGrin Cool
#104 Posted : 10 December 2011 12:31:33
BigGrin As ussual an excelent start m8
#105 Posted : 12 December 2011 22:57:11
ISSUE 5 Parts 17 - 18 - 19 - 20
Hi team I have completed the Hull planking up to date here are a few photos:-
#106 Posted : 12 December 2011 23:00:51
ISSUE 5 PARTS 17 to 20
The next photos show the Hull with planks in a raw state lots of shaping ond sanding to do:-
#107 Posted : 12 December 2011 23:04:48
ISSUE 5 17 to 20
MERRY CHRISTMAS AND A HAPPY NEW YEAR, TO YOU AND YOUR LOVED ONESLove Love Love Love
#108 Posted : 29 December 2011 14:19:45
Hi Mike
Looking great is she, single or double planked on hull.
Ian Cool
#109 Posted : 29 December 2011 15:15:38
Hi Ian, thanks for your nice comments, she is single planked as far as I know, but I will keep you postedBigGrin
Cheers Mike
#110 Posted : 15 January 2012 13:23:37
ISSUE 5 PARTS 21 TO 24
Hi Team I started by fitting the Port and Starboard side Deck Plates,and as MR T found, rib 24 was lower by 2mm than the others so I packed it with a scrap piece of 5x2mm planking(see Photo) I then glued them and put some pins in to hold till set.
Thats all this timeBigGrin Mike
Dontshootme
#111 Posted : 15 January 2012 17:53:50
Forgive me asking Mike,but if 24 was 2mm lower then surely 25 is as well?
Asking this because the deck seems to slope down,also I hope to be resuming my Vic build & starting this & Hood as well.
#112 Posted : 15 January 2012 17:57:21
Hi Rob, no it was only rib 24 for some reason, and I know my ribs were well pushed home.
Have a look at The offical build same thing happened to MR TBigGrin strange or what?
Cheers
Mike
#113 Posted : 21 January 2012 19:06:22
ISSUE 5-6 PARTS 21 TO 28
Hi Team
I have finished planking the Hull with the long planks,when the adhesive is dry I will take the ship off the Dry Dock and then finish the planking of the Hull with the short planks.
The decks have been dry fitted,as per the instuctions,and the aft deck pieces have been stuck together
Here are the photos:-
MikeBigGrin Cool
#114 Posted : 21 January 2012 22:00:08
BigGrin Looking good there Mike
#115 Posted : 21 January 2012 22:16:36
Thanks AndyBigGrin Much appreciatedBigGrin MikeCool
#116 Posted : 24 January 2012 19:21:32
ISSUES 5-6 Parts 21 to 28
Hi Team here are the latest photosBigGrin of the build:-
#117 Posted : 24 January 2012 19:24:51
Could not resist thisDrool
#118 Posted : 24 January 2012 19:27:20
BigGrin Coming along nicely Mike, im 1 issue behind you so you give me an idea of whats next in lineLOL
#119 Posted : 24 January 2012 19:41:38
Thank you Andy for your commentsBigGrin I am about to take her off the Dry Dock board now, to get at the sides and bottem of thr Hull betterBigGrin Regards
MikeCool
#120 Posted : 27 January 2012 15:01:11
Mike,
You have the middle deck section upside down, the long slot should be on the port side, see step 3 on page 110 of the steps
Guest (7)
9 Pages «<45678>»
This page was generated in 0.361 seconds.
