3 Pages 123>
Astronuts HMS Surprise Options
astronut01
#1 Posted : 26 January 2012 14:45:19
Rank: Amateur Level 1
Hi all
Recently subscribed to the 28 part Surprise build. Here are my first impressions and pics:
Parts 1 and 2
Parts 1 and 2
Part 3
astronut01
#2 Posted : 26 January 2012 14:48:25
A few more pics:
Size comparison with the Endeavour Longboat, which is scaled at 1:50.
Am having real problems lining the deck up with mast positions. Did anyone have to sand the deck to get it to fit with the mast and frames?
budgie
#3 Posted : 26 January 2012 15:23:48
BigGrin hi Astronut
i built a jig for false keel then glued the frames making sure sitting square
once all dry i fitted the false deck OK
The false deck is tight and may i suggest wetting the deck first this will make it more flexible and less likely to split (learnt that the hard way)
The only sanding of the false deck was on the edges so they ran smooth with frame edges
Hope this gives you some help
#4 Posted : 26 January 2012 15:36:35
Hi Astro You are doing a great build,BigGrin I agree with Budgie you really need to set the keel, in a Dry Dock Jig using a base board and angle bracketsBigGrin Regards Mike
#5 Posted : 26 January 2012 19:35:02
I third that BigGrin
#6 Posted : 26 January 2012 20:27:50
I forth that.as budgie has got past that prob. I would listen to him,if there was a prob.budgie found it,and has gained a lot of experience on the way.what may also help is when you have got the jig set up and if you have glued the ribs,soak the rib joins with a paint brush and hot water,this will free up the glue and placing the deck will be a lot easier and it also squares everything up better.then just let dry,provided it is placed in the jig,it should dry up all nice and square.good luck.this is the most important stage of the build,to make sure everything is square and straight.
Ger C
#7 Posted : 27 January 2012 02:21:04
Love the look of the Surprise
but should not bite of more than I can chewLaugh
Ger
Ger C
#8 Posted : 27 January 2012 02:27:23
Already have the End longboat and the Akagi underway and my wife bought me the San Fran 2,
someone told me that this was an addictive hobby but if I get any more ships I dont think that I will get any finishedLaugh
Ger
#9 Posted : 27 January 2012 09:35:51
Hi Ger I find it is best for me If I finish the Hull of each model first, working alternitavly between the shipsBigGrin Regards MikeCool
astronut01
#10 Posted : 27 January 2012 14:23:14
Thanks all for the advise on the jig, I'll knock one up this weekend.
Can anybody tell me what comes with issue 4 if the kit?
Many thanks
budgie
#11 Posted : 28 January 2012 00:00:04
Blushing Memory not so clear those days
Cool but some issues are lacking in parts but other issues you get loads of stuff
Blink so do not be disheartened (and i am a girnin' old fart)
BigGrin it's a big build BigGrin for inspiration of what can be achieved may i suggest you follow HudsonRobert & Magpie build logs for inspiration
Please bear in mind that not everyones build will be exact to each other due to material,enviroment, your measuring stick (left eye shut right eye 6/20 vision, your interpretation of colour etc)
i got heehawed due to lack of plans, not for content, delivery, quality or help from admin MrT Magpie Hudson robert or from other forum members
Wishing you every successs with your build but may i suggest this is a 5 anchor difficulty job
so if you feel frustrated TAKE A STEPBACK ask the question on the forum and wait untill you feel ready to proceed
Sorry for the long girn happy building
billbo
#12 Posted : 28 January 2012 18:23:19
Many thanks
hi mate iam on issue 7 and in 4 and issue 5 you get more planks and in 6 you get a thing that the boat sits on for working on the boat hope that helps also in issue 7 is wallnut planks
building the spitfire,RMS Titanic hachette and now starting the u-96 submarine
astronut01
#13 Posted : 09 February 2012 14:36:55
Hi all
thanks for all the tips. Managed to get the false deck in ok. Have started planking the false deck. Haven't decided whether to trenail it. I'm really enjoying this model.
Received notification that the next issue is on the way, that'll be number 4 for me, so I can get on to the hull. That's one of my favourite jobs!
Kind regards
moriarty
#14 Posted : 09 February 2012 14:51:01
you gotta trenail it cos it looks the bussiness on a boat that size. just clock robs and magpie , if that dont sway you dont know what will. while we are on the subject of decking ,anybody got a sure fire way of displaying the caulking. i have physically put rigging rope on earlier models but it can be finicky and limits sandingConfused .any of you guys great ideas will be deeply mulled over and implimented when the time comes.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
astronut01
#15 Posted : 09 February 2012 15:03:39
I'll see how it goes. It's a lot of work to trenail this deck though, only for it to be covered over.
astronut01
#16 Posted : 10 February 2012 09:56:47
Almost finished with the gun deck planking:
need to trim the overhangs and sand.
#17 Posted : 10 February 2012 10:37:40
Good stuff AstroBigGrin Regards MikeCool
hudsonrobert49
#18 Posted : 10 February 2012 10:48:48
Looking good, Just wait till you start the planking.
Rob
Bridlington.
astronut01
#19 Posted : 10 February 2012 14:18:28
Does anybody know with what issue does the tool kit come with?
astronut01
#20 Posted : 21 February 2012 14:21:13
I decided to trenail the false deck after all. I used a 0.5 mechanical pencil with a 2B lead:
3 Pages 123>
This page was generated in 0.277 seconds.
