56 Pages «<2223242526>»
MWG build diary of the mighty Hood Options
#461 Posted : 26 January 2012 19:38:13
ISSUE 21
Using a steel rule an a sharp knife I cut off the lip:-
#462 Posted : 26 January 2012 19:40:35
ISSUE 21
Then I fitted the Deck:-
#463 Posted : 26 January 2012 19:42:51
ISSUE 21
This is how she looks now:-
Question and comments welcomeBigGrin thank you for watchingBigGrin Regards
MikeCool
#464 Posted : 26 January 2012 20:16:04
Oh WOW!! She is getting better and better mate!! Drool ThumpUp
S2ksean
#465 Posted : 26 January 2012 20:20:09
She a beauty mike. I copyied ur idea about using a knife ta cut off the edge. Il put up the photo in min
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#466 Posted : 26 January 2012 20:48:16
Thanks Jonny I apreciate your comments as usualBigGrin Regards MikeBigGrin Cool
#467 Posted : 26 January 2012 20:49:51
Cheers Sean no problem, thats what the build is forBigGrin we help each otherBigGrin Regards MikeBigGrin Cool
#468 Posted : 30 January 2012 16:50:50
Shes starting to look like a ship now mike, do you think that they will resin mould the stern and possibly front bow section bottom. ian Cool
#469 Posted : 30 January 2012 19:21:24
BigGrin Starting to come together nicly MikeCool
#470 Posted : 30 January 2012 21:45:41
Hi Ian I am not sure is that whwy they did with the Bismark? Regards MikeBigGrin
#471 Posted : 30 January 2012 21:46:47
Hi Andy thanks again for your continued supportBigGrin Regards MikeCool
#472 Posted : 31 January 2012 15:03:05
Hi mike yes bismarck did have a resin stern and bow pieces. looking at your hood build might be small resin peice in front of bow and psibbly some planking round top of bow to the narrow top, stern possibly resin piece on to back lug on stern. on the other hand i could be wrong ?. ianCool
S2ksean
#473 Posted : 01 February 2012 17:09:32
Spot on the money mike we got planks. Nice guess lol
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#474 Posted : 06 February 2012 10:38:10
ISSUE 22 PLANKING THE HULL
Hi Team this what we received:=
2 Bow plates 113 and 114 (port and Starboard)
These pieces need trimming and sanding for a good fit on the Hull
We also received 20 planks (part 115) the planks are fitted 10 per side, 4 + 4 + 2 = 10 running from Bow to Stern.
#475 Posted : 06 February 2012 10:47:24
I have posted a selection of photos, so you will see the plank fitting:-
#476 Posted : 06 February 2012 10:52:32
ISSUE 22 HULL PLANKING
This photo shows the fitted planks how they should look when this weeks build is completed:=
#477 Posted : 06 February 2012 10:55:09
and how she looks nowBigGrin Questions and comments are welcomeBigGrin
MikeBigGrin
#478 Posted : 06 February 2012 11:04:49
BigGrin Hi Mike
starting to look the bizz now shes getting some flesh on her bones,keep up the great work
S2ksean
#479 Posted : 06 February 2012 21:10:16
Looking great mike. Il hopefully be doing mine on wednesday so is there anything I should look out for?
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#480 Posted : 06 February 2012 21:53:19
Thanks Andy for your kind commentsBigGrin Hi sean thanks mate, just make sure you apply the planks correctly 10 either side as per the instructions.BigGrin
MikeBigGrin
Guest (10)
This page was generated in 0.362 seconds.
