Varnishing Options
JAW
#1 Posted : 26 January 2012 20:49:16
Rank: Beginner Level 3
Hi All,
I am up to issue 83 and I was wondering, would you recommend varnishing the top decks at this point, it has not said so in the magazine (unless I have missed it) but I can see I might not get such a good finish once I have added the canons and stairs.
Thanks again
JAW
#2 Posted : 26 January 2012 20:58:37
that would make sense to me
benny
#3 Posted : 26 January 2012 21:52:51
me too, once you have got the decks as you want them get them sealed,add the details then give another coat and so on 3 or 4 coats of varnish wont hurt plus its a dust repellent if your wood is still slightly rough even with a stain the dust will get caught up
cheers benny
Ger C
#4 Posted : 27 January 2012 02:07:54
Hi,
new to this type of modeling but I presume that the wood needs to be varnished or oiled,
should this be done as the stages progress or left to the end,
thanks,
Ger
#5 Posted : 27 January 2012 10:55:32
Hi Ger C. As Benny and Jase have said do it as you are going along. The more coats the less dust can settle into cracks. Hope this helps
JAW
#6 Posted : 27 January 2012 18:59:55
Thamks guys
I will varnish my upper decks tonight. After I have made the thirty four posts for the timber heads. Is it just me or is getting harder and harder to keep up.
JAW
benny
#7 Posted : 28 January 2012 13:59:14
JAW wrote:
Thamks guys
JAW
hi dont worry about keeping up take your time i am also way behind the build but its more important not to rush things
cheers benny
Ger C
#8 Posted : 30 January 2012 01:58:05
lovely build, keep up the work
This page was generated in 0.319 seconds.
