4 Pages <1234>
Ger C Akagi Options
Ger C
#21 Posted : 27 January 2012 01:43:44
While the glue was drying I started on the bow block, while I was glueing the parts together I noticed that there were small gaps so I stopped and clamped everything together, will finish it off tomorrow.Cool
Ger C
#22 Posted : 27 January 2012 01:46:46
By the way, reduced the size of my pics, hope that this makes it easier for you to view,
as always all comments are welcome,
thanks,
Ger
#23 Posted : 27 January 2012 21:17:33
BigGrin Hi Ger
i had the same problem as you with the bow sections and resorted to clamping too, my pics are sized 700 by 700 and they fit quite well on the pages,and its coming along a treat
Ger C
#24 Posted : 28 January 2012 18:50:00
Andy,
Thanks for the advice,
Ger
Ger C
#25 Posted : 04 February 2012 02:25:50
Hi all,
I have finished gluing the stern section,
please see the attached pics
Ger C
#26 Posted : 04 February 2012 02:30:50
I have also added the remaining parts to the bow section, as previously noted gaps were appearing so I stopped and clamped,
not entirely happy with my work but a little sanding to the rear should give a flat surface,
as always all comments are welcomeMad
#27 Posted : 04 February 2012 10:38:23
BigGrin Hi Ger C
Its comming along nicely m8,your work is fine. The bow/stern sections are cut oversize so after a good sanding all your errors will dissapear.
Ger C
#28 Posted : 04 February 2012 12:21:48
Hi Andy,
thanks for your kind commentsBigGrin
Ger C
#29 Posted : 12 February 2012 02:37:38
Hi all,
have started the dreaded planking, am fairly happy with the results but realize that some sanding will be necessary,
Ger
#30 Posted : 12 February 2012 10:54:54
Lots of sanding, filling and priming will be necessary if you are to loose the outline of the planking beneath the surface.
Ger C
#31 Posted : 21 February 2012 00:41:49
Hi all,
I ran into a problem with my planking, when test fitting the first long plank I realized that something was wrong as it was not following the line of the notches on frames 14 - 12. After some head scratching I realized that there was a gap below frame 13.
Either I did not push it home properly or I did not use enough glue and dislodged frame when inserting frame 28Blushing
I removed frame 13 and shaped the base so that it now fits, am glad that I took the time to figure out the problem rather than trying to force the plank to fit/
lesson learned,
Ger
Ger C
#32 Posted : 21 February 2012 00:43:12
PS
will post some pictures of my planking effort later in the week,
Ger
#33 Posted : 21 February 2012 16:57:24
BigGrin Glad u spoted it before you got too far Cool
Ger C
#34 Posted : 21 February 2012 17:58:42
Thanks Andy,
Would have been a nightmare if I had to rip the Planking out,
Will consider this as part of the learning curve
Ger
Ger C
#35 Posted : 22 February 2012 00:09:23
Hi all,
Advice needed,
What degree of tolerance is permissible, one or two of my frames are less than half a mm above the others,
Not really sure as how a wooden model should fit together,
All advice welcome,
Ger
Ger C
#36 Posted : 27 February 2012 00:50:09
I managed to get a bit more work done today, am taking my time to try and get the best results and most of all am enjoyingit so far,
Ger
#37 Posted : 27 February 2012 08:33:38
Goot start GerBigGrin Regards MikeBigGrin
Ger C
#38 Posted : 27 February 2012 17:55:03
Thanks for the kind comments Mike,
Ger
#39 Posted : 27 February 2012 18:29:21
BigGrin Looking good gerCool
Ger C
#40 Posted : 09 July 2012 02:05:11
Sorry that I did not update soonerBlushing ,
I have made some progress with the planking but was not happy with some,
in particular I found that the planks did not stick to frame 11 so removed these and will redo,
funny that this only happened on the starboard sideConfused ,
will post some pics soon
4 Pages <1234>
This page was generated in 0.614 seconds.
