7 Pages «<34567>
MWG build diary of the San Francisco ll Options
#81 Posted : 20 January 2012 23:00:10
Thanks JaseBigGrin Now to finish the sides,and then a good sanding!!!
Cheers MikeCool
#82 Posted : 23 January 2012 01:26:33
PLANKING THE SIDES
Hi Team, I am now halfway up the port sideBigGrin The sides are proving to be easier than the Hull.
On reading the instructions, they say make sure the Gun Ports are enlarged to 10mm square, I am glad I read this before I planked over them, because it is much easier cutting out the ply. the Gun Ports are pre-cut at 8mm square.BigGrin
Comments and questions welcomeBigGrin
MikeCool
Ger C
#83 Posted : 23 January 2012 01:39:34
Mike,
She looks fantastic,
is she an easy kit to build?
Ger
#84 Posted : 23 January 2012 01:47:13
Ger, she is not difficult, because she is small but the planks are mahogany, and take time to bend and formBlink
MikeBigGrin
#85 Posted : 23 January 2012 14:44:15
HI Mike, love the look of that mahogony. I presume that it is to be clear varnished or are you going to oil it? Both ways it will really look fantastic. I love the colour of natural wood.
#86 Posted : 23 January 2012 14:58:04
Hi Hans, Thank you
I will probably use Danish oilBigGrin
MikeCool
#87 Posted : 27 January 2012 20:24:44
PLANKING THE HULL AND SIDES
Hi Team well the planking is finishedBigGrin ,I have to trim the plank ends, plus cut out rhe port holes, and finally sand and prepare the Hull and sides, not muchBlink Huh but at least I can move onBigGrin here are the photos:-BigGrin
#88 Posted : 27 January 2012 20:30:43
And here is how she looks at the momentBigGrin
Comments and questions welomeBigGrin Thank you for watchingLove Regards
MikeBigGrin Cool
#89 Posted : 27 January 2012 21:07:28
Coming along nicely Mike
#90 Posted : 27 January 2012 21:10:43
Thanks for the encouragement AndyBigGrin Regards MikeBigGrin Cool
#91 Posted : 29 January 2012 13:38:24
The trimming of the Hull and Gunnels is going according to planBigGrin Regards MikeCool
#92 Posted : 29 January 2012 14:39:31
BigGrin As ussual Mike top notch work
#93 Posted : 30 January 2012 00:32:30
Thanks for the nice comment AndyBigGrin Regards MikeCool
Ger C
#94 Posted : 30 January 2012 02:02:41
Mine just arrived,
cant wait to get startedLOL !
Ger
#95 Posted : 30 January 2012 08:38:25
Well done GerBigGrin Please take your time on the plankingCool Blink Huh Regards Mike
Ger C
#96 Posted : 30 January 2012 14:16:42
Thanks Mike,
Will do a bit more work on my Akagi before starting the San Fran,
At first glance there seems to be a lot in the box,
Am looking forward to starting,
Ger
SteveKent
#97 Posted : 06 February 2012 12:00:36
Rank: Newbie
Hi, really nice looking build.
My friend is building this too and would like to know what you are planning to do with sealing the decks and hull. (He says there is nothing in the instructions).
Will you be varnishing or oiling, and if possible could you let me know exactly what materials you are planning to use please?
Thanks,
#98 Posted : 06 February 2012 21:56:38
Hi Steve
I sealed the decks with Ronseal water based matt varnish, I will use Danish oil on the HullBigGrin I hope that helpsBigGrin
MikeBigGrin Cool
#99 Posted : 06 February 2012 22:54:22
Its going to look stunning in that dark wood.Cool
#100 Posted : 06 February 2012 23:00:41
Thanks JaseBigGrin
MikeBigGrin
Guest (6)
7 Pages «<34567>
This page was generated in 3.043 seconds.
