23 Pages «<910111213>»
HMS Surprise build log (Robert) Options
moriarty
#201 Posted : 09 February 2012 15:55:53
it looks good and the trenailing sets it off, done to admiralty spec i presumeLaugh i have read that you can do it by rubbing a soft lead pencil(chippy one maybe) on just one side of the plank. i thought about a black permanent marker but will it bleed through and cause discolourationConfused . all the pro books say pencil but it is always better from the man on the job, learning by mistakes an all that.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
hudsonrobert49
#202 Posted : 10 February 2012 16:52:41
Mine are on the left theirs on the right, I ask u, theirs look like Chinese cannons.LOL LOL LOL
Rob
Bridlington.
#203 Posted : 10 February 2012 17:02:24
Very nice work RobBigGrin Regards MikeCool
moriarty
#204 Posted : 10 February 2012 21:23:14
do we get a prize for which one,s you use
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
saintsman123
#205 Posted : 10 February 2012 23:22:54
those other guns look like some machined parts i saw a while ago, and i can't think what they were used for. they certainly do not look like guns at all.
Come on you Jimmies
Dontshootme
#206 Posted : 11 February 2012 08:44:22
They look almost like the pins used to hold on replacement wiper bladesBlink
hudsonrobert49
#207 Posted : 11 February 2012 09:11:54
nope too easyLOL
Rob
Bridlington.
riff-raff
#208 Posted : 11 February 2012 09:43:35
RE: Corking
I use black electrical tape for the corking. I cut a length into 1mm strips and then superglue it to one side of each plank and then glue each plank together.
Very tedious but the results look good also no bleed or smudging
Dave
Built:
hudsonrobert49
#209 Posted : 20 October 2012 14:56:39
LOL Well I've Picked up the craft knife againLOL , I'm Well behindLOL I should be doing it for a couple of hours Every day I hope LOL
I will post pic's as I go along, if there worth putting on LOL
Rob
Bridlington.
Mo
#210 Posted : 21 October 2012 18:23:11
No excuse now, look forward to watching your build progress.
Mo
Mo
#211 Posted : 21 October 2012 18:55:49
The correct cannon should be corronades, here is a photo:-
I hope you dont mind me showing this?
Kind regards MikeBigGrin
hudsonrobert49
#212 Posted : 22 October 2012 09:22:53
NO I don't mind at all looks great as well, n thanks to a kind friend Ive now got full 1:1 mast plans.
Rob
Bridlington.
hudsonrobert49
#213 Posted : 22 October 2012 09:35:15
The wire snaps too easily.
Rob
Bridlington.
#214 Posted : 22 October 2012 09:41:27
hudsonrobert49
#215 Posted : 22 October 2012 10:46:27
I NEED better wire as the one supplied KEEPS snapping Cursing
Rob
Bridlington.
#216 Posted : 22 October 2012 11:11:09
hi bob if you heat the wire it stops it snapping,I use a gas lighter.
hudsonrobert49
#217 Posted : 22 October 2012 11:20:26
Hi Karl, I'll give that ago thanks for the tip.
Rob
Bridlington.
hudsonrobert49
#218 Posted : 26 October 2012 13:13:08
Painting the inner lower deck walls
Waiting for the post man to bring me some Hooks for ropes for the cannons.
Rob
Bridlington.
hudsonrobert49
#219 Posted : 26 October 2012 16:59:01
Here are some of the Rigging Hooks that I got Today before n after They have been blackened, Carr's metal blackening for Brass.
next Ive got to attach the gun ropes to them, Mmmm hope i can pull it off.Confused
Rob
Bridlington.
Mo
#220 Posted : 27 October 2012 08:39:43
Hi Robert,
I used the carrs solution, it was a while ago now, but I seem to do exactly what the instruction told me to do, but after 24 hrs in the solution there was hardly any colour change, so I left in the container and went on 2 weeks holiday, when I got back things were fine,
Mo
Mo
This page was generated in 0.323 seconds.
