2 Pages 12>
sandnesspeats Options
sandnesspeats
#1 Posted : 11 February 2012 17:05:28
Hi Folks,
Cursing Cursing I think I have a disaster looming,the photos show large gaps which I have just noticed,No idea what to do about that or should I go on with the build.The deck is flush with each other meaning the holes for the mast is spot on but it looks like the hull frames are too big.
This is my first build,might have bit off more than I can chew,but I try.
Any help would be greatly appreciated.
great site I must admit,BigGrin BigGrin
sorry for the fuzzy photo. the third photo is were I am at.
thanks again
getting nervous now LOL
Confused Confused
sandnesspeats attached the following image(s):
saintsman123
#2 Posted : 11 February 2012 17:33:28
not sure what to suggest except try a few rows of hull planks, see if it comes in to line again, it may be that some sanding and filling may be required which would be ok if you are painting or tiling.
Come on you Jimmies
Son of Bulwark
#3 Posted : 11 February 2012 18:13:25
Hi sandnesspeats! Cool
Don't worry mate there isn't a problem with your build its the way the deck was laser cut, my lower deck at the stern didn't fit to the hull either.
You said,"This is my first build,might have bit off more than I can chew,but I try." take smaller bites and chew well! Just joking, it’s a partwork that has been geared up for the first time builder and what you have done looks ok! Keep up the good work and enjoy your build.
Darron
sandnesspeats
#4 Posted : 11 February 2012 18:13:57
Thanks for that,It might just do that if I angle the planks a bit more maybe or build up the frames a bit so as to look not so out of place,Just wish I had seen it earlier,DOH!!!
sandnesspeats
#5 Posted : 11 February 2012 18:17:46
Thanks for that son of bulwark,feel as if I can go on now with a bit more confidence.Blushing Blushing Blushing Mellow
Son of Bulwark
#6 Posted : 11 February 2012 18:27:05
I meant to add the following:-
The lower deck won't be seen, if you want to fill the gap between the deck and the hull you can use filler or a plank shaped to fit over the underside of the deck then glued in place. The small gap at the corners between the last frame and the underside of the gallery will be filled after you plank the lower hull.
I hope this helps mate!
Darron
alantait
#7 Posted : 11 February 2012 18:28:43
Hi sandnesspeats, i agree with the replies, i also had gaps and as darron says take your time, enjoy the build its a great project, when planking lay them over the frames and as i had to do either sand down or add card or plank fillers. best of luck
current builds
sandnesspeats
#8 Posted : 11 February 2012 18:47:43
Thanks again,
I have to admit that I really enjoy doing this,when I seen that gap I was horrified,just never noticed, as the ship was upright when doing the planking and ports,so never noticed it.
I have read most of the posts and found some people saying about the planks being different thickness's,well all I did was to file the width of the frames in the back of the plank,were it was higher,and seemed to work ok.I am not saying that they are perfect but it looks a bit better.One last thing I presume the cannons which I have built do not go in to the ports that I have cut out as they don`t fitBigGrin BigGrin
sorry for ranting but I am cheered up now to carry on.
This is a very helpful forum for the absolute novice.
Great stuffCool Cool Cool Cool
Son of Bulwark
#9 Posted : 11 February 2012 19:01:59
There are 10 cannons that go on the upper gun deck and 6 cannons on the quarter deck. Dummy cannons are used on the rest of the gun ports, fitted in the holes drilled into the beams.
Darron
sandnesspeats
#10 Posted : 11 February 2012 19:11:00
Cheers mate,That`s a relief, I thought there was a misprint LOL.Laugh Laugh Laugh
z8000783
#11 Posted : 11 February 2012 19:42:05
Groups: Unapproved
Absolutely and it's not a joke, break EVERYTHING down into stages.
One thing though, I can see from the pics but you may want to do a bit more fairing at the stern to get a nice, smooth shape around the back.
Have a look here.
Nice to have you aboard.
John
sandnesspeats
#12 Posted : 11 February 2012 21:01:25
Thanks John,do you mean at the very back or the frames at the back,I see your picture is nearly flat at the stern almost level up from 2mm part???
pleasure to be here with all the experts.BigGrin BigGrin BigGrin
z8000783
#13 Posted : 12 February 2012 12:03:30
Groups: Unapproved
That was not my build, that was Toms, the official build.
Here's mine.
I too am a newbie, so please don't take my words as gospel but the I have completed the planking now and the stern doesn't look to bad.
John
sandnesspeats
#14 Posted : 12 February 2012 12:29:40
I see from the photos that the stern is almost level with the centre,I just assumed that it has a little height for the rudder to slot in to.Confused Confused Confused `cos mine is 2mm higher than the centre were the rudder goes,hope you understand that bit.BigGrin BigGrin
z8000783
#15 Posted : 12 February 2012 12:49:25
Groups: Unapproved
Have a look at Issue 20 picture 3.
John
sandnesspeats
#16 Posted : 12 February 2012 13:27:37
Thanks John,I will take it to nearly level.
thanks for your help.Cool Cool Cool
z8000783
#17 Posted : 12 February 2012 16:46:20
Groups: Unapproved
ThumpUp
Start up your diary and you'll have somewhere to ask questions and post pictures, and lots of them and it doesn't matter how trivial. It's better to check than carry on with the possibility of having to pull bits of your ship apart to fix something.
John
sandnesspeats
#18 Posted : 12 February 2012 18:17:19
Hi John,
how do I set up a diary everything is new to me so do I just do what I have been doing by posting stuff etc .I am just about to do issue 32 so looks a bit fidgety to do but I will post some photos as I go to see if I am doing it right
rob
Thanks again
#19 Posted : 12 February 2012 18:23:28
BigGrin Hi Sand
to set up a diary go to the members build logs section of the forum then to the victory build part. At the top of the page you will see post new subject tab , click on it name your diary and start posting
Hope this helps
sandnesspeats
#20 Posted : 12 February 2012 22:12:42
thanks for that,but for the life of me I cannot find it,there is official model build and then general discussion etc.Blushing Blushing Blushing
cheers
rob
I have some photos I need advice on.
2 Pages 12>
This page was generated in 0.292 seconds.
