Its not bad to have abilities stretched as it is what keeps a build interesting, well done CMB
looksr real good “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Brilliant mate...a really fantastic job there...keep it up!!  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
Nice build mate You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
Joined: 23/03/2010 Posts: 205 Points: 598 Location: West Midlands
Thank guys for all your kind words. Special thanks to Mr T for his build diary and tips, without these I would not have been able to achieve the results as shown so far. I just hope the mast building goes as well when I get to that stage. Thanks for looking and happy building to you all. CMB
No need to thank me CMB, its what I do and only too happy to help you on your way
Realy great build CMB. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Now into February and the build continues, albeit somewhat slowly. Since my last update I spent some time tidying up the gun ports as they did not look square when the hull was sitting on the keel, this took a little time but I think well worth the effort. Painted the hull as per the instructions and masked off the various areas in order to paint the bands. Once painted some defects in the hull became obvious and a little light sanding was required to rectify Next came the fitting of the steps and fenders, the steps in particular I found very fiddly but managed to line them by eye and I am happy with the end result. At the moment I am not really happy with the copper paint finish so a better brush is on my shopping list next time I am in the nearest art shop. All the masking tape is still in place until the painting is complete The fighting top was built and painted as per the magazine, although I had to add 2mm inserts in order to have enough material to drill the smaller holes 24mm in from the sides, I hope this does not come back to bite me later in the build. CMB attached the following image(s):
Really great work CMB  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Coming on well CMB You'll likely need to enlarge the mast top holes when it comes to inserting the bound deadeyes at 94.
Tomick wrote:Coming on well CMB You'll likely need to enlarge the mast top holes when it comes to inserting the bound deadeyes at 94. Thanks for that Mr T. I will have a look at that over the weekend. CMB
Joined: 06/08/2011 Posts: 480 Points: 1,421 Location: Galway
Looks very good to me, you must be v happy, Ger
Looking good CMB, your build is looking great. Slow is good. Makes for a better model and allows you to think before you build. Less kit bashing later when you have a better plan. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
For those who have glanced at my build diary over the past few months you will have no doubt noticed that I had skipped over the mast building/assembly instructions and gone on to paint the hull. The reason being that I was not at all sure if I was up to the shaping and carving that was required. Well I could not put it off any longer, so purchased a length of 10mm dowel from my local timber merchant as I expected to have several attempts and using the supplied dowel had my first crack at the lower main mast. Surprise, surprise it worked out OK and the other two sections were completed as per the magazine and Mr Ts instructions. Photographs taken and I am very happy with the result The next challenge will be the rigging, I have opted for the 'no sails' & Standing rigging but she who must be obeyed says that I should fit the sails, time will tell. Now to tidy up the hull painting before starting on the next mast. If anybody spots a clanger shout loud before I screw up. Happy building to you all CMB
Very nice job CMB  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Grest pictures CMB - your build is looking splendid!
Well done for jumping in.
John
Thanks for the nice comments guys. I am now really enjoying this build and wish that I had started years ago. May have a go at the Mississippi Steam Boat next. Cheers all and happy building CMB
Since my last post I have glued the top two sections together and fitted the rigging blocks.I found it easier to line up the mast this way than by starting with the lower section,and the two seperate sections can now be stored easily until it is time to fit to the hull. I am now working on the mainyard and remenber that there were some issues with the brass wire being very brittle, had a look at SOBs solution and think that could be the way to go. Anybody know what size cord should I use? Happy building to you all CMB CMB attached the following image(s):
 Hi CMB Doing a fine job there m8,its strange when you keep putting stuff off then try it and suprise yourself with the results of the chalenge involved,great stuff keep it up regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
