gun port lids Options
saintsman123
#1 Posted : 14 February 2012 23:53:15
just an idea to give the gunport lids a bit of support when fitting, you can drill a hole at the rear and fit a headless nail, or small piece of brass wire, then drill a hole in the hull for the nail to fit into. it hepls stop them breaking off too easily.
Come on you Jimmies
#2 Posted : 15 February 2012 08:19:31
Sounds like a very good idea...I will definitely be considering employing your method...thanks mate...ThumpUp
z8000783
#3 Posted : 15 February 2012 09:09:11
Groups: Unapproved
Me too. If it can fall off it will, seems to be a maxim for my builds.
John
riff-raff
#4 Posted : 15 February 2012 09:23:49
Nice idea
Built:
saintsman123
#5 Posted : 15 February 2012 10:28:35
glad you all like the idea
Come on you Jimmies
farrabass
#6 Posted : 15 February 2012 11:05:07
I can confirm that this approach works, I have done this procedure with the first lot of gunport lids that will be obscured by the channels.
As has been suggested a small hole drilled in the end of the lid and a cut off pin inserted with the point sticking out!, this negates the need to drill a second hole to accept the pin. Line up the lid with the edges of the gunport and carefully manouvre the lid up from that point and then gently push the lid in towards the final possition, pull the lid away and either the the pin will stay pinned to the hull or will remain attached to the lid. It is just a matter of deciding if the lid is in an acceptable possition or readjusting the lid to suit, when the final possition has ben decided on, a small drop of super glue on the pin and a drop at each end holds everything in place Securely.
Steve..
#7 Posted : 15 February 2012 12:27:35
I would just like tp add a slightly different method which I used,as the hinges supplied are oversized,they very neatly slot into the top of the gunports.I slotted my lids into the gap between the gunport liner and porthole,that way you can adjust the angle you want the the gunport to be.
just check my build and have a look.
saintsman123
#8 Posted : 15 February 2012 12:53:13
another good idea karl
i thought about bending them up and having the ends showing above the gun ports, but didn't like the look, and some of the wiggles got in the way.
i have also drilled all the hinges and fitted nails through all the hinge holes, it takes ages as i have to fit the nail first then clip off the point and then file them flat, and finally give it another coat of stain, but it's one of those jobs you can do at night while watching the telly. the finshed look is quite good, i'll put some pics up on my diary once i finish the shrouds.
on another point, i got some injections on monday and have stsrted to get a little bit of feeling back in my hand again so fingers crossedBigGrin
things should get easier from now on.
Come on you Jimmies
#9 Posted : 15 February 2012 14:48:01
That's fantastic news about your hand. Take care and believe and it will heal.
#10 Posted : 15 February 2012 16:45:57
nice one saint,keep them digits moving,great news m8.
saintsman123
#11 Posted : 22 March 2012 15:37:42
just a heads up for anyone getting to this stage.
having fitted all the lids using a pin, so they were all secure, i still managed to dislodge a couple while rigging the shrouds, ratlines, stays etc, if i was doing this or a similar build again, then i would fit the lids around the same time as fitting the dummy guns to stop any damage, anyone coppering the hull as an afterthought should really copper before fitting the lids.
it may just be my clumsiness, as my hands don't always do as my brain says, but i do think fitting them as late as possible will help stop any accidentily being knocked off.
Come on you Jimmies
z8000783
#12 Posted : 22 March 2012 16:09:32
Groups: Unapproved
Thanks Bob.
Coppering the hull will be my next task.
John
This page was generated in 0.069 seconds.
