14 Pages 123>»
sandnesspeats Options
sandnesspeats
#1 Posted : 18 February 2012 16:35:40
I am at issue 32.
the bow is looking very iffy,the plank is not level to the upper one, i seem to be going straight down instead of following the curve of the framesCursing Cursing ,hope you can see the photos ok!
Q.do i take off the upper one and try again and angle the plank more???Confused Confused
A.?????????
Any help would be great,don`t want to go any further.
cheers GurusMellow Mellow Mellow
sandnesspeats attached the following image(s):
alantait
#2 Posted : 18 February 2012 18:31:29
Hi, looks like you might be trying to bend it to fit the lower plank, let the plank take its own natural curve and use stealers or fillers to fill the gaps, to see these look at some of the other build diarys. i had a few planks that were not the same width throughout the length so be aware of these and use them for small sections.
hope this helps
current builds
sandnesspeats
#3 Posted : 18 February 2012 22:39:37
thanks for your help,I am trying to make it level with the lower plank,but there are 2 frames that are lower than the rest and cannot seem to get it level until I put fillers at the back to bring it level and seems to go out of wack with the frames,hope you understand that.BigGrin BigGrin
#4 Posted : 18 February 2012 23:10:43
Hi a lot of people used balsa fillets inbetween the bow and stern formers[then sanded down to profile] as this helps with getting the shape to these sections corect and adding more glueable area. I do realize this might be a bit late in your build to mention this but keep at it and it will all come fine
sandnesspeats
#5 Posted : 19 February 2012 18:14:51
I think I managed it, to a fashion anyway,I will just horse on as they say,I needed a bit of patience for that part I have to admit.
I see what you mean about the fillers in between the frames,I seen that a bit too late as you say.
thanks mate.
Cool Cool Cool
z8000783
#6 Posted : 19 February 2012 18:25:49
Groups: Unapproved
You'll need some droppers in there very soon as well, as I found out to my cost.
John
moriarty
#7 Posted : 19 February 2012 19:41:58
Hi sandness, keep at it, you will get there and you will always learn from your mistakes. Here is a picture of my victory. It was the first wooden model I tackled and I made plenty mistakes on that ,can you spot any on it cos they are still there. It is about 6 yrs old now.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
alantait
#8 Posted : 19 February 2012 20:38:15
from your photograph, she looks ok, now it will start to give gaps as you let it take the natural curve of the wood, this is where she will require fillers(as i found out) keep it going ( we are all in the same boat - as to say) - hopefully be up your way in the summer - and would like to see the final model... best of luck.
alan
also look at johns shambles - he states he is having problems - but she looks good to me
current builds
sandnesspeats
#9 Posted : 19 February 2012 23:54:24
moriarty-would not insult to pose a comment on any other builds,looks great to me.
alantait your welcome to visit if you are near sandness,just let me know ok!! Final model HA!!!!!!!! was it this summer you were thinking of coming here or in about 5 yearsLOL LOL LOL LOL to see mine.
Great advice from you all I see where all the problems lie,my build looks very messy compared to what I have seen.see what happens when I go further down the build eh!!!
thanks again all
Cool Cool Cool Cool Cool Cool Cool Cool Cool
sandnesspeats
#10 Posted : 26 February 2012 13:20:41
Hi All,BigGrin BigGrin
I need some of your expert opinions,I would like you to look at these photos,I am waiting for my electric plank bender and I want to make sure of everything before I continue. Have I done enough fairing on these parts,I was thinking of putting some balsa wood like I have seen on other builds.
Thanks in advance.
Dontshootme
#11 Posted : 26 February 2012 17:39:02
Your stern frames need more work unfortunately,the outer piece of play shohould be flush with the keel,you have a groove from the looks of it....sorry.
sandnesspeats
#12 Posted : 26 February 2012 19:12:52
hi,could you explain what groove is and how to fix it and outer piece of play ??????
thanks
#13 Posted : 26 February 2012 19:33:13
BigGrin Hi Peats
i think play should be ply m8,so it should say your outer piece of ply should be flush with the keel
saintsman123
#14 Posted : 26 February 2012 20:02:21
I think you should check with mrT , as I think it looks ok. There should be a groove for bow sticky out bit to fit in.
look at the official build diary.
http://forum.model-space.co.uk/resource.ashx?a=877
Come on you Jimmies
sandnesspeats
#15 Posted : 26 February 2012 22:49:53
ah!! thanks so it is just about flush,will keep looking CLOSELY at the official build in future. Hope you don`t mind me putting more pictures just to check before I go any further.
thanks guys
Cool Cool
z8000783
#16 Posted : 27 February 2012 09:16:43
Groups: Unapproved
Just to be clear, it is the stern you are talking about NOT the bows.
The false keel need to be flush with last rib and the rib needs to be flat not curved in towards the keel.
John
Dontshootme
#17 Posted : 27 February 2012 09:43:41
My bad...it should indeed have said ply & not play.
Saint...the groove you are referring to is at the bow of the ship & has to be created with your planking,the groove I am referring to is at the stern where the last frames are added,a groove is left between them the thickness of the keel,the frames need to be sanded down so that the whole stern is flush with the keel thus eliminating the groove...hope this has cleared up any confusion.
saintsman123
#18 Posted : 27 February 2012 10:51:58
I missed the top picture rob, I see what you mean now.
Come on you Jimmies
sandnesspeats
#19 Posted : 27 February 2012 11:17:01
hi, it was both I was talking about being flush,sorry for any confusion,seems a lot to take off and that is why I am asking.
thanks again
rob
z8000783
#20 Posted : 27 February 2012 11:48:30
Groups: Unapproved
There is a lot to take off, in fact the rib almost disappears.
John
14 Pages 123>»
This page was generated in 0.411 seconds.
