22 Pages «<89101112>»
Stefan's build Options
#181 Posted : 07 February 2012 08:55:11
Good stuff StefanBigGrin Regards MikeCool
StefanDV
#182 Posted : 13 February 2012 11:38:04
Thanks Mike,
I managed to get all the Cannons fitted over the weekend, so here are some pictures:
2 of the cannons on the Starboard side. The rope tails still need to be cut to the same length and the restraining rope fitted to the leftmost cannon - Fitting the rings through the eyes caused a cussword or 2.
All the cannons on the Starboard side fitted:
In order to get the cannon barrels to sit centrally in the gun ports, the all the wheels butting up to the ribs on the Port side had to be thinned significantly.
All the cannons fitted
#183 Posted : 13 February 2012 11:45:30
Job very well done Stephan, keep up the good work and the flag flying high.
StefanDV
#184 Posted : 20 February 2012 11:37:48
Thanks Hans,
Some more progress over the weekend:
Made a little jig to ensure the holes for the dummy gun barrels would sit squarely in the gunports:
Shaped the rudder:
Built the ladders:
StefanDV
#185 Posted : 21 February 2012 09:25:41
Fitted the handrails for the companionway ladders
and the bitts
Hoping to get a start on the quarterdeck support beams this evening.
#186 Posted : 21 February 2012 09:34:13
Really good work StefanBigGrin Regards MikeBigGrin
#187 Posted : 21 February 2012 10:52:55
Excellent work Stefan...Great job done mate...Keep the pictures coming...ThumpUp
StefanDV
#188 Posted : 22 February 2012 08:18:45
Thanks Mike & Jonny!
Managed to complete the quarterdeck supports last night.
Starting at the bow
The fitting of the planks from frame 21 onwards was a little tricky, but thanks to the excellent instructions and Tomick's brilliant build dairy I managed to complete it without any major mishaps.
View from the stern
Atholm
#189 Posted : 22 February 2012 09:03:16
A very neat build well done keep it up.
Happy building
Athol
StefanDV
#190 Posted : 23 February 2012 09:35:46
Thanks Athol!
Started planking the quarterdeck last night
Made some clips to hold the planks to the already fitted ones:
The Stern
Middle
and Bow
z8000783
#191 Posted : 23 February 2012 10:51:28
Groups: Unapproved
Love the Upper Gun Deck, well done.
John
Foz
#192 Posted : 23 February 2012 20:56:21
Great work there Stefan. keep up the good work.
Foz
#193 Posted : 24 February 2012 12:45:13
Good building there Stephan. looking very good neat and clean.
moriarty
#194 Posted : 24 February 2012 14:07:53
great going but you know what , it is always a shame to cover over all that craft and you are the only one that knows it is there. Why can,t we build in perspex so everyone can appreciate all the hardwork that goes into these thingsLOL . it is looking good though.Cool
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
StefanDV
#195 Posted : 28 February 2012 08:08:12
Thanks Gents!
This is my first wooden ship build Moriarty, never thought of doing part of it in perspex ;)
Finished the quarterdeck planking over the weekend
#196 Posted : 28 February 2012 08:28:37
Hi Stefan, for your first wooden ship build your work is exceptionalBigGrin Regards MikeBigGrin Cool
StefanDV
#197 Posted : 29 February 2012 07:46:49
Thanks Mike!
A little attention to detail and a dash of patience goes a long way.
Managed to cut the timber-head openings and the top row of gun-ports last night
Started lining the bulwarks
StefanDV
#198 Posted : 08 March 2012 11:38:55
The bulwarks lined
As the bulwark linings ended up 1mm short of the hull, a decking plank was fitted sideways on top of the lining planks and against the outer hull. This plank was then sanded back to get an even height
All the gunports and the timberhead opening on the port side lined, starting on the starboard side
The gun ports lined and sanded down:
View from the Starboard side
#199 Posted : 08 March 2012 14:50:51
Well done Stefan you have a real flair for this. Looking darn good.
StefanDV
#200 Posted : 09 March 2012 07:36:39
Thanks Hans for your most gracious comment!
Guest (7)
This page was generated in 0.403 seconds.
