29 Pages «<1920212223>»
karls new victory build Options
StefanDV
#401 Posted : 22 February 2012 08:12:28
Well done Karl.
Thanks for all your great hints and tips!
Atholm
#402 Posted : 22 February 2012 09:10:52
She is coming on very nicely.
I like your method of fabricating the centre pin rails.
Happy building
Athol
#403 Posted : 22 February 2012 18:19:06
the centre pin rails and rear transom decoration fitted.
#404 Posted : 10 March 2012 14:39:47
here I'm attempting to emulate the knightheads(that thingy that holds up the anchor)
http://www.pbase.com/mic...lszewski/image/57403554
I've done this in the sandwich method,I used scaps of 6mmx1mm.the pics will explain all.if anyone wants the dimensions of the bits used just shout.sorry not up to s.o.bs graphic artistry.
that's it for now,got to add the wedgy things to the knightheads and a bit more paint.
saintsman123
#405 Posted : 10 March 2012 16:20:47
good idea karlBigGrin
Come on you Jimmies
#406 Posted : 11 March 2012 11:34:13
#407 Posted : 12 March 2012 16:36:29
I've started on the shrouds only to experiment with whippings,and the general overall look.comments very welcome,good or bad,I won't mind changing or redoing it if it is not right.
I will be dropping back to filling up the cannonball racks and rigging the guns on the deck.
saintsman123
#408 Posted : 12 March 2012 17:28:32
hi karl
did you use the fly fishing method of preparing the deadeye/shroud lashings? as the lashings look a little big for the rest of the shroud, i only say this as you are looking for some feedback. perhaps prepare the lashings on a smaller drill bit/dowel/nail or whatever you use. i went off track when i did mine, as the magazine pictures of lashings on the actual victory looked different to the way described in the step by step. i tied the shrouds to the deadeyes in 3 places
1. on the top of the deadeyes
2. around 10mm up from the deadeyes
3. around 3mm up from the deadeye
the picture i used for reference was on page 13 of issue 92 the black and white drawing
it also meant that i had physically tied the shroud to the deadeye so i knew it wouldn't slip
also i know the front cover pictures are not quite what we are building but it looks as though thats was the way done there.
hope you don't mind me telling you this karl, especially with your modelling experience, which i glean from all your diaries
keep up the good workBigGrin
Come on you Jimmies
Son of Bulwark
#409 Posted : 12 March 2012 18:17:06
Hi karl!
I see you haven't fitted the hammock cranes and netting yet, you will find it hard to fit them with the shrouds lashed in place mate.
Also I'm sorry to tell you that the ekeing rail on your port side is fitted to the upper beakhead rail while your starboard ekeing rail is fitted to the lower beakhead rail.
Darron
#410 Posted : 12 March 2012 18:43:18
thanks for the feedback gentlemen,saint first,having another look at the lashings and see if I can reduce the diameter.sob I did have an idea of fitting the hammock cranes already made up,gonna put me thinking cap on.and will correct the bow end.
#411 Posted : 26 March 2012 14:23:26
right,first I've corrected the bow stringers(sob)then removed the lanyards so I could fix the crane nets.and finally lashed the bowsprit.
StefanDV
#412 Posted : 26 March 2012 14:37:44
Well done Karl - your build is coming along splendidly!
saintsman123
#413 Posted : 26 March 2012 16:03:41
nice work karl.ThumpUp ThumpUp
i think it's a bit easier to put the shrouds and other rigging on before the gunport lids, as i kept getting the lashing thread wrapped around them and pulled a couple off in the process.
Come on you Jimmies
#414 Posted : 26 March 2012 16:58:09
BigGrin looking good Karl
#415 Posted : 26 March 2012 18:48:31
thanks for the comments gents,yes saint agree the gunport covers should have been later.
#416 Posted : 26 March 2012 19:55:21
Cracking good job there Karl..Its a great build mate!!...ThumpUp
#417 Posted : 28 March 2012 12:21:53
this is where I'm at,at the moment,fore and main mast shrouds done,mizzen just started,I had a roll of softish wire 1mm. so I cut a piece of 5mm.x2mm. x 20mm.plank and used that to make up the deadeye spacers so that I couls adjust as I went along.
farrabass
#418 Posted : 28 March 2012 13:14:26
Cracking along at a good pace!
Dont know how you have the time to do so many kits at once?
I struggle with the two I have at the moment.
Steve..
#419 Posted : 28 March 2012 13:19:10
hi steve,a very understanding wife,thinks she wants me out of the way,as long as i cook,washup,and hoover she is good as gold.BigGrin
#420 Posted : 25 April 2012 14:22:47
all the hammocks done the forestays,wiggles,and the first stay sail.
This page was generated in 0.188 seconds.
