Joined: 06/08/2011 Posts: 480 Points: 1,421 Location: Galway
Andy is right, Uploading from the pc or phone is much easier, Good luck, Ger
Joined: 09/02/2012 Posts: 569 Points: 1,675 Location: Scotland
Thanks for that Andy, still cant get it that way, I need to get the hang of this if I am to do a log. I right click the mountain icon, and then choose the " go to my pictures " I can then get all my pictures up from that particular folder, but how then do I attach it to my post ? Spending more time on my pc than on my boat. Hey Ho ! ! I cant even get a smiley on the screen. Mo Mo
 Hi Mo what i do is tick 'attach files to this post' box after you put in text,then it should open up into the new page with browse box ok, browse your pics on PC or Phone then click/highlight the 1 you want then below that in your pics folder it should have a comformation tab at bottom click this ,it should then be highlighted in the text box next to browse button on the post pics page,then just click on upload box next to it,the number of the pic should then appear above the browse box,then its just repeat till u have all the pics you want above the browse box, then click post at the bottom of page to add to text,hope this helps and its not too confusing, im terible at trying to explain things regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 [/img] Mo
 [/img] Mo
 Last attempt at trying to upload pictures. Mo Mo
Good stuff Mo  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
Looking good there Mo keep the pics coming. Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Mo wrote:Kit arrived, But not what I was expecting, 26 boxs, Parts 1 - 28 with the exception of parts 8 & 10. The keel was not marked as to where the frames go, and the frames were not marked by number either, Anyway after some working out, got all the frames and deck all glued up, It looks like a boat now, Still trying to work out the loading of pictures, Think the last pictures posted were a fluke.
Mo Maybe that is why she's called the Surprise
 Mo
Still having problems getting pictures on the posts, anyway a couple done now, Just picking away at bits and pieces, as you can see, Top halk of the hull planked now and gun ports cut out, reasonabaly happy with my efforts. Mo Mo
  [/img][IMG] Mo
 [/img]This is my twist check. I put a piece of wood on the stern and a piece on the bow, If the top of the bow timber lines up with the bottom of the stern timber the ship is in line, no twist. Getting the hang of the pictures now, By the way I have ordered some wood filler before there is any comments about my planking. Yours Mo the novice Mo
 [/img] Mo
 [/img] Mo
 Looking good Mo keep up the good work,by the way i use ronseal high perfomance wood filler,easy ti use and sands well regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 [/URL] [/img] Mo
 Mo
 Mo
