3 Pages <123>
willie's hood Options
willie
#21 Posted : 05 March 2012 21:12:15
two inner shafts fitted now
S2ksean
#22 Posted : 06 March 2012 21:40:53
Looks great willie.
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
willie
#23 Posted : 06 March 2012 22:00:34
all the shafts in few adjustments and ready for the second planking when that is home made A brackets all made and ready for fitting on end of shafts when i know there true lengh
willie
#24 Posted : 06 March 2012 22:11:55
the A brackets for the end of the shafts stil to be cut to size
#25 Posted : 06 March 2012 22:43:36
Nice job WillieBigGrin Regards MikeBigGrin
willie
#26 Posted : 23 March 2012 17:03:13
second planking stbd aft
willie
#27 Posted : 02 May 2012 17:44:55
back end with rudderand a brackets
willie
#28 Posted : 02 May 2012 17:47:43
#29 Posted : 02 May 2012 18:04:18
Now that is going to be fast, well done Willie Cool
#30 Posted : 02 May 2012 19:46:02
Hi Willie, you are doing a great jobBigGrin Regards Mike
willie
#31 Posted : 02 May 2012 21:04:17
cheers MIKE AND TOMIC haven't made up my mind to take the rudder down to the keel or leave her large its only 10 mm to come off the bottom i think there plenty of rudder left if i do
willie
#32 Posted : 16 May 2012 13:40:59
found it figgty to fit the doors i removed the doors from the fret and place the fret over where the door should be carefully put glue at the door space and placed the door back in to the fret one door lined upremove fret when finish
willie
#33 Posted : 29 November 2012 22:52:57
bow fitted nice fit needs a little tidy up quite pleased with it
Virtue86
#34 Posted : 30 November 2012 17:15:37
Hi Willie,
Its looking good, looking forward to getting that bow section for mine, will be good to get the hull complete when i start working on her again next year. Keep the pics coming.
Cheers
Peter
Current builds: Amati 1:200 Hood; D51 200
Bought and on the waiting list: HMS Endeavour's Longboat, 1:90 San Juan Nepomuceno, Titanic Lifeboat,1:200 Bismarck Strip and Rebuild
[b]Built:1:250 Titanic
Tiswas
#35 Posted : 30 November 2012 17:41:11
Nice build there Willie, still undecided about the RC.
TIS
#36 Posted : 08 January 2013 01:34:56
Hi Willie.
Looking fantastic. How did you find putting the propeller shafts through the hull planking. I found this a bit tricky on my bismarck had to modify holes on the rear ribs as prop shafts were bigger than the holes in rib. Keep the pictures coming ian Cool
willie
#37 Posted : 08 January 2013 10:41:36
it was done by a little trick i have i use a brass tube the same dia as the stern tube in this case a 6mm diax300mm long with one end cut like a hole saw [i had already boared the holes in the frames be fore fitting them ]sliped the tube through the frames and drilled from the inside out the tube cuts the hole oval due to the shape of the hull but round if you know what i mean, aslo made a steady plate out of the ply fret for the motor end to keep it the right hight and spaceing for the gear boxes if you use this idear you got to be careful and watch the tube dose not follow the line of the plank other words where the plankes are glued to each other
#38 Posted : 08 January 2013 13:27:33
Great idea Willie. Look forward to seeing some more of your build Ian.BigGrin
willie
#39 Posted : 08 January 2013 14:26:16
Ian if you wonder about the wooden outer tubes the red and blue ones they are wooden paint brush handles the shape has a slight bulge on them near to the shap of the real ones boared with a 6mm drill leaves a 1.5mm wall
willie
#40 Posted : 08 January 2013 16:46:47
one of my boring tools for doing shafts an other way of boring the shafts but you need a set of tubes that fit in to each other 2mm to 6mm this time you find the centre of the shaft line and bore 2mm hole in the hull and frames and fit the 2mm tube. the next tube that fits over this one cut the ends so it will drill and slip it over and drill this tube through do not remove repeat with the next tube alwas leave the last tube in this acts as a guide for the next tube till you reach the size you requier this drilling can be done from the out side in remember to draw the tude back and forth when dilling to clear the cutting ---i have fitted bow thrusters also this way useing tubs up to 16mm
3 Pages <123>
This page was generated in 0.149 seconds.
