Joined: 30/01/2011 Posts: 865 Points: 2,410 Location: Cambs
great work hans Come on you Jimmies
 Rank: Pro  Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Well done Hans - she's looking spectacular! All the extra effort and detail you're putting in is really paying off.
Great Job Hans  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Thanks Comic123, Saint, Stephan and Mike, appreciate your support. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hans, Hello, I have just looked at your post ! welcome to the miniature world,your furniture look's very much the part,it's pleasing to see your effort as I am well aware of what it takes to complete,it just shows the skill level you have.I think the day cabin with the lights look's as if you are about to sit for a meal, as for the red curtins and round table spot on Hans.Also to take in to consideration that you had to remove the Galley without damage and to go to all this that's dedication. The upper deck, I think the cannons look the part, along with your colour of the deck all in all great effort,look forward to more pictures. regards trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Thanks Trev. Trust me when I say the skill still needs plenty of honing. I found that jewellers head gear with varying lenses helps a lot. Makes life a little easier not to mention seeing better. Thanks for the compliments and encouragement. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
hans this is a guy in the uk's work, i have seen him on t.v. a few times and as far as miniature work goes, i think he is the master. he uses things like the hair from a fly as paintbrushes......yes a fly...., and has to slow his heart rate down, and paint in time with his heartbeat to avoid the slightest movement. some of the sculptures are made from a single grain of rice. http://www.willard-wigan.com/gallery.aspxCome on you Jimmies
Thanks Bob, very very impressive, the guy must have a extreme amount of patience, particularly with figures. I'm not sure I'll go that far. This was purely an exercise to be slightly different and take owership of the ship and make it personal. Although must admit liked the idea of being challenged, especially as this is my first build. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
 Outstanding quality build Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 13/01/2012 Posts: 605 Points: 1,630 Location: Bucks
that is some link HMS Surprise HMS Snake HMS Bounty HMS Royal Caroline HMS Victory rebuild HMS Supply
Thanks Ar, appreciated. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Fantastic build hans keep up the good work ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks very much for the kind words Ian. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Joined: 25/03/2011 Posts: 1,027 Points: 3,075 Location: Lincolnshire
Hi Hans,
That's a really neat build you've got there, and its a credit to you. Can you tell me what you used to get such a glossy finish on the hull in post 30?
Regards Glenn
Hi Glenn, thanks for the encouragement. I used a 25% reduced imbuia matt varnish on the deck and teak gloss varnish on the hull. It is the type used on outside wooden decking for our harsh sunny conditions. I only used three coats with a light sanding in-between coats, to avoid it showing up too yellow. I brushed it on and it closed up the brush marks quite well. Hope this helps. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hi all, for those that might be interested,I discovered a 12 volt LED strip that come in 5 metres flexible self adhesive roll and you are then able to cut every 3 LED's. It has a positive and negative patch on either end, where you can solder the wires in series for corners, bends, extentions etc. I have used a fine comms cable, the one used for security gates and intercoms, that I strip for the lenghts I need. A laptop 12 volt battery charger reduces our 220v to 12vdc. Looks fantastic when lit. If it helps I can post the specs. I have not found that the LED's produce too much heat, it only provides 4.8 to 5w alum. The strips themselves appear to be a foil of sorts that defuses the heat as well. Trust this helps your cause. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Joined: 11/09/2011 Posts: 227 Points: 677 Location: Heidelberg South Africa
Hi Hans Like your detail & lighting, stunnig mate Regards Pierre Current Buid: HMS Victory Next Build: Captain Cook's Endeavour Collecting issues Wish List: Santa Ana Bounty Santisima-Trinidad
Stunning work! Greetings, Walter
Thanks for your support Pierre and Dadokta. A little behind with the updates. Busy with the masts at the moment. plenty of work and hours and you wonder if you will ever finish. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Joined: 04/06/2012 Posts: 19 Points: 57 Location: Pretoria (SA)
I like the idée with the LED’s, your build is looking good Hans Built Albatross, build in 1982 from plans. Hms Bounty, build in 1987 from plans. Duyfken,build in 1991 from plans Oosterland, build in 1998 from plans
In the meantime. HMS Victory (Deagostini) 2011 Building MFV63 fishing trawler from plans. HMS Mayflower (Kit)
Wish list Still planning.
Guest (13)
