Joined: 11/05/2011 Posts: 766 Points: 2,128 Location: Dagenham
Lol no worries I look forward to seeing it CURRENT BUILDS
Mclaren MP4-23 Ford 1/12 Shelby Mustang GT500 2010 HMS Pandora
Issue 25 (part 2)     Plankings not same both sides but it's as close as I could get it CURRENT BUILDS
Hi Sean very nice job  And the photos are great  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Sorry guys just had a thought for the new peeps who are just staring out. Glue as I found out early on in the my build is obviously very important. I used any old run of the mill superglue when I first started which wasn't good and got told off by a few members for doing it lol. This is what I'm using now  I'm not sure if this is what others are using but I've had no problems so far with it and it's worked extremely well plus once it's dry it's easy to sand off and it's water proof CURRENT BUILDS
Should be fine Sean  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 20/04/2010 Posts: 545 Points: 1,536 Location: lossiemouth
that's the glue i am useing
Issue 26  It will look alot nicer once it's all been sanded and cleaned up CURRENT BUILDS
Good stuff Sean  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Cheers mike il put up some more progress later hopefully CURRENT BUILDS
Issue 27     Thats the hull complete (ish)   Now it's starting to look like a battleship all it's missing is guns lol. Il put up few more pictures after it's all sanded down and smooth then it will look better. I'm quiet pleased with the result so far considering I was worried about the planking I think it's gone ok. Comments welcome CURRENT BUILDS
well done on the planking,dont go to daft sanding ,just the high spots the second planking will sort out anny minor dip,a little filler wont go a miss here and there if you think it needs it
Cheers willie I wasn't sure if it was double planked. I haven't been using nails so far just clamps so il have to get some cause there won't be anything to clamp them to CURRENT BUILDS
theres double planking on the hull it goes right around the bottom i think it start the from the top of the deck and the top deck is sanded back to the first planking so it sits in side the second and the second planking is usely put on with impact glue no need for nails if useing impact and i have bough small powerfully magnets on e bay 6 mm x6mm dia and they clamp the planking to geather 20 for a few quid
Hi Sean, Willie is right the second planking comes approx at issue 30. regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
when sanding back the deck watch your angle you think you have a lot to sand but the angle at the front section is about 20 deg down to about 10 deg at the removeable section to nearly 0 deg at back end of this section just follow the planking angle the book tell you about the front none removable section and to follow the thin ply wood part this gives you the right angles, dont sand the thin ply wood, when you tuch the frames you know you are there
Joined: 30/01/2011 Posts: 865 Points: 2,410 Location: Cambs
nice work sean Come on you Jimmies
Joined: 25/01/2012 Posts: 134 Points: 385 Location: Berwick Upon Tweed
Looking really good sean. I hope to have mine at this stage in the next couple of weeks. I like willie's idea of using magnets for the second planking layer but if you want to use pins I bought some ultra fine peco track pins from a model shop for about £1.50 and they will do the whole ship. Just depend whether you want to fill the pin holes or not. Cheers Peter
Current builds: Amati 1:200 Hood; D51 200 Bought and on the waiting list: HMS Endeavour's Longboat, 1:90 San Juan Nepomuceno, Titanic Lifeboat,1:200 Bismarck Strip and Rebuild [b]Built:1:250 Titanic
Hi filling the pin holes will not be a problem, because we will be sanding and spray painting  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Need help guys. I haven't glued down the decks to the hull cause I wanna put lights in the ship but I don't no where I can get decent lights from can anyone help CURRENT BUILDS
Hi i think maplins do light sets led's ect and also hobby stores do dolls house lighting not sure if you can bend this to your design though regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (6)
