10 Pages «<678910>
Sean's HMS hood Options
S2ksean
#141 Posted : 27 February 2012 20:57:37
Lol no worries I look forward to seeing it
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#142 Posted : 06 March 2012 18:10:26
Issue 25 (part 2)
Plankings not same both sides but it's as close as I could get it
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#143 Posted : 06 March 2012 19:08:13
Hi Sean very nice jobBigGrin And the photos are greatBigGrin Regards MikeBigGrin Cool
S2ksean
#144 Posted : 07 March 2012 18:34:34
Sorry guys just had a thought for the new peeps who are just staring out. Glue as I found out early on in the my build is obviously very important. I used any old run of the mill superglue when I first started which wasn't good and got told off by a few members for doing it lol.
This is what I'm using now
I'm not sure if this is what others are using but I've had no problems so far with it and it's worked extremely well plus once it's dry it's easy to sand off and it's water proof
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#145 Posted : 07 March 2012 18:40:03
Should be fine SeanBigGrin Regards Mike
willie
#146 Posted : 07 March 2012 22:19:50
that's the glue i am useing
S2ksean
#147 Posted : 16 March 2012 10:33:20
Issue 26
It will look alot nicer once it's all been sanded and cleaned up
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#148 Posted : 16 March 2012 13:44:13
Good stuff SeanBigGrin Regards Mike
S2ksean
#149 Posted : 16 March 2012 15:10:17
Cheers mike il put up some more progress later hopefully
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#150 Posted : 16 March 2012 18:37:32
Issue 27
Thats the hull complete (ish)
Now it's starting to look like a battleship all it's missing is guns lol. Il put up few more pictures after it's all sanded down and smooth then it will look better. I'm quiet pleased with the result so far considering I was worried about the planking I think it's gone ok.
Comments welcome
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
willie
#151 Posted : 16 March 2012 18:57:19
well done on the planking,dont go to daft sanding ,just the high spots the second planking will sort out anny minor dip,a little filler wont go a miss here and there if you think it needs it
S2ksean
#152 Posted : 16 March 2012 19:14:38
Cheers willie I wasn't sure if it was double planked. I haven't been using nails so far just clamps so il have to get some cause there won't be anything to clamp them to
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
willie
#153 Posted : 16 March 2012 19:37:20
theres double planking on the hull it goes right around the bottom i think it start the from the top of the deck and the top deck is sanded back to the first planking so it sits in side the second and the second planking is usely put on with impact glue no need for nails if useing impact and i have bough small powerfully magnets on e bay 6 mm x6mm dia and they clamp the planking to geather 20 for a few quid
#154 Posted : 16 March 2012 21:36:29
Hi Sean,
Willie is right the second planking comes approx at issue 30. regards Mike
willie
#155 Posted : 17 March 2012 20:55:51
when sanding back the deck watch your angle you think you have a lot to sand but the angle at the front section is about 20 deg down to about 10 deg at the removeable section to nearly 0 deg at back end of this section just follow the planking angle the book tell you about the front none removable section and to follow the thin ply wood part this gives you the right angles, dont sand the thin ply wood, when you tuch the frames you know you are there
saintsman123
#156 Posted : 17 March 2012 23:31:27
nice work seanBigGrin
Come on you Jimmies
Virtue86
#157 Posted : 19 March 2012 19:48:59
Looking really good sean. I hope to have mine at this stage in the next couple of weeks. I like willie's idea of using magnets for the second planking layer but if you want to use pins I bought some ultra fine peco track pins from a model shop for about £1.50 and they will do the whole ship. Just depend whether you want to fill the pin holes or not.
Cheers
Peter
Current builds: Amati 1:200 Hood; D51 200
Bought and on the waiting list: HMS Endeavour's Longboat, 1:90 San Juan Nepomuceno, Titanic Lifeboat,1:200 Bismarck Strip and Rebuild
[b]Built:1:250 Titanic
#158 Posted : 19 March 2012 20:06:34
Hi filling the pin holes will not be a problem, because we will be sanding and spray paintingBigGrin Regards Mike
S2ksean
#159 Posted : 18 July 2012 17:51:19
Need help guys. I haven't glued down the decks to the hull cause I wanna put lights in the ship but I don't no where I can get decent lights from can anyone help
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#160 Posted : 18 July 2012 18:00:33
Hi i think maplins do light sets led's ect and also hobby stores do dolls house lighting not sure if you can bend this to your design though
10 Pages «<678910>
This page was generated in 0.247 seconds.
