26 Pages «<2122232425>»
MWG build diary of the Bark HMS Endeavour Options
#441 Posted : 19 March 2012 12:21:59
ISSUE 60
Hi Team in this issue we received Stern transom (two pieces),300x4x4mm ayous wood strip, 300x5x5mm ayous wood strips, pully wheels and Rigging blocks (4mm).
The Transom shows 5 windows, but the real ENDEAVOUR only had 4, the centre one was not a window because it was over the Rudder.Parkinsons drawings show this in the Anatomy of the shipBigGrinRegards Mike
#442 Posted : 19 March 2012 20:15:33
Hi Team,
I have purchased a lovely piece of Mahogany 1 metre long 2mm thick, I will be using this instead of the tacky ply to make the companion ways and covers on deckBigGrin Regards Mike
#443 Posted : 03 April 2012 14:06:00
ISSUE 61
This week we received the following parts:-
An oven flu
Pulley wheels
Bow gunwale (three pieces)
300x5x1mm ayous strips x6
300x6x1mm ayous strips x2
300x5x2mm ayous strips x4
Mike
#444 Posted : 03 April 2012 14:10:55
ISSUE 62
And in this edition we received:-
Breakwater (6 pieces)
Raw cotten thread (0.15mm)
Belaying cleats
300x4x4mm ayous strips Regards Mike
#445 Posted : 03 April 2012 14:22:30
HULL COLOURS
As you all know from my previous posts I have been looking at a different medium to colour the second planking than paint and I chose ink,Ink in my opinion shows the grain much better than paint, I published the Orangy yellow colour some weeks ago, now I have found the blue for the planks below the gunwales.It is Rowney Acrylic Rowney Blue
For the Wales and anchor linings I will use black ink.
I may use ink for all the deck fittings, but I have not made up my mind yet.BigGrin comments and Questions welcome. Regards Mike
alantait
#446 Posted : 03 April 2012 16:48:57
cheers mwg, will head to town for this colour of ink, it certainly gives a better finish than the paint option.
alan
current builds
#447 Posted : 03 April 2012 19:54:34
Thanks for your comment Alan, when you see the ink on the ayous wood the effect is outstandingBigGrin Regards Mike
#448 Posted : 07 April 2012 15:14:29
ISSUE 63
Hi Team this week we received Windlass gear (metal) Windlass large winch (metal) Windlass small winch (metal) these parts are better quality.
Also received Pulley blocks(4mm) Rigging blocks (4mm) and the Windlass, (six pieces in wood).
I will now be starting the second plankingBigGrin Comments welcome.
Regards MikeBigGrin
#449 Posted : 16 April 2012 23:18:33
ISSUE 64
This week we received the following this week:-
The small Windlass winch cast alloy
The large Windlass winch cast alloy
The ships Bell brass
The Belfry cast alloy
The Windlass Figures and dead eye blocks (7mm)
Regards MikeBigGrin
#450 Posted : 24 April 2012 14:51:07
ISSUE 65
Last week we received the following:-
Taffarel leaf decorations and stern windows.
Eyebolts
300x2x2mm ayous wood strip
Brass wire (1.5mm diameter)
Tiller bridge and hatch cap (nine pieces
Regards MikeBigGrin
#451 Posted : 24 April 2012 15:03:41
STERN MODIFICATION
Hi Team I decided to change a few things with the stearn of the ship, as you know I have the Anatomy of the ship Endeavour, the vessal did not have 5 windows at the rear, only 4 windows,and the centre was covered by woodwork as it covered the Rudder Tunnel and was a sham.
First up I made two new stern pieces from my Mahogany I had purchased and cut holes through the wood so that the windows when fitted would have depth:-
#452 Posted : 24 April 2012 15:10:59
STERN MODIFICATION
Next I retained the stern front plate and fitted the windows at the rear of this plate (It is a good idea to retain the brass lugs on the window frame for fixing on the plate, otherwise they may fall through):-
#453 Posted : 24 April 2012 15:17:18
STERN MODIFICATION
So now the windows from the front have depth.
Next we prepare the centre sham, I cut a piece of Mahogany and fixed it into the rear, and taking the centre window I cut out all the spars and fitted the remaining window frame in the centre:-
#454 Posted : 24 April 2012 15:22:03
STERN MODIFICATION
I had some brass beading and I decided to use this instead of wood battons,I think it looks better and more authentic:-
IAN
#455 Posted : 24 April 2012 15:25:26
Hi Mike..
The Endeavour is looking great.
Best regards,
Ian
Ian
Wish list: Bentley Blower
#456 Posted : 24 April 2012 15:28:18
STERN MODIFICATION
Well Team here is the finished result,I do not know if I will use blue on the stern or just varnish it. The beading has to be trimmed and permanently fixed. also I will fit acetate behind the windows maybe yellow Thanks for looking Questions and comments welcomeBigGrin Regards Mike
harty
#457 Posted : 24 April 2012 15:39:36
Excellant little tip that about keeping the lugs on. Good call.Love
#458 Posted : 24 April 2012 15:53:54
Love what you have done Mike...All good stuff mate!! Love ThumpUp
alantait
#459 Posted : 24 April 2012 18:31:07
Hi Mike, i think that this looks alot better, just what i was thinking about doing, as for the acetate i think that might work depending upon how transparent it is with no real interior.
no doubt i will find out when i finally get to doing this myself
current builds
#460 Posted : 25 April 2012 08:06:39
Thank you, Harty, Jonny and Alan for your nice comments, much appreceiatedBigGrin Regards Mike
This page was generated in 0.473 seconds.
