mainmast chain wales diagram issue 75 Options
vindiboy57
#1 Posted : 20 March 2012 15:02:17
Rank: Beginner Level 1
has anyone noticed the differance between the upper main mast chain wale diagram to the lower one (the one with the dead eyes attached) if so which one is correct as the slots dont line up. thanks' may you lead line never touch bottom
saintsman123
#2 Posted : 20 March 2012 15:33:56
not sure which pictures you mean, but don't forget that the chainwales are a mirror image of each other they are not identical
Come on you Jimmies
vindiboy57
#3 Posted : 20 March 2012 17:51:46
if you get a chain wale match it up with top diagram then draw it down to the one with deadeyes on they dont match
#4 Posted : 20 March 2012 19:01:12
think you'll find that one pic is port an 'tother is starboard.
vindiboy57
#5 Posted : 20 March 2012 21:49:10
so i take that the one on the bottom, the bow is on the right i understand the mirror image not reverse image
jeff averre
#6 Posted : 20 March 2012 21:56:21
You are dead right Vindiboy,
the diagram can be confusing, normally a plan view is under a side view, but in this case it's not?
I mentioned this a few weeks ago when I was at that stage, I tend not to put 100% faith in either plans or instructions as errors have on occasion been made, just double check everything from photo's or Tomick's instructions.
Jeff
vindiboy57
#7 Posted : 20 March 2012 22:13:57
THANKS JEFF I KNOW I'M NOT THE SHARPEST MARLIN SPIKE BUT I THOUGHT SOMETHING DIDN'T ADD UP
saintsman123
#8 Posted : 20 March 2012 23:02:19
glad your sortedBigGrin
Come on you Jimmies
This page was generated in 0.242 seconds.
