32 Pages «<678910>»
#141 Posted : 25 March 2012 16:08:29
onwards with this months build,now its the dry mounting of the bilg keels [theses will be permamently fitted after the final hull shaping].Firstly mark out as instructed then add the pins to the keels,here i made a change the instructions say to use a pin to make the holes needed but i found this split the ply so i opted to drill the holes instead.All thats left for this month is the fiting of the propeler shafts but as i have a few enhancements planed here it will take a little longer before pics are posted ,as ussual all comments are welcome
#142 Posted : 26 March 2012 19:56:43
A bit more on the Akagi enhancments iv been planing around the stern/screw area.Firstly i followed the intstructions as per the download but then took off an extra 1mm from the shaped dowels,then useing plastic card sheet i made and shaped two blanks to the desired dimemsions and glued these to the dowels to represent the rivet flange ussaly associated with this area,il add drops of pva after final fitting to represent the rivets.Il also be adding the same type of enhancment to the screw shaft suports and adding some airofoil type shaping to the aliminium supports aswell.As ussaul all comments are welcome
#143 Posted : 26 March 2012 23:02:26
really enjoying your build. like the screw construction plastic card idea.
Cool
#144 Posted : 27 March 2012 01:34:53
Hi Andy I love your enhancementsBigGrin Regards Mike
#145 Posted : 27 March 2012 21:27:34
BigGrin Thank you both Jase and MikeCool
Silent_Running
#146 Posted : 28 March 2012 09:18:44
Top job Andy ThumpUp BigGrin
#147 Posted : 28 March 2012 23:40:56
BigGrin Thank Cool you for the comments lads
#148 Posted : 21 May 2012 17:34:52
Crying My build is being held up at the moments as i recieved pack 10 today but am still awaiting the resending of pack 9, il update as soon as things are on track again
Ger C
#149 Posted : 21 May 2012 23:43:04
I had the same problem earlier,
Looking forward to the next stage of your build
#150 Posted : 04 June 2012 23:50:26
Finaly got pack 9 on friday so on with the build,made up the various hangar and lift components then fitted the armour belts to the hull. the hull is still prety much bare bones as il be fitting the screws,rudders and bilges after the final hull shaping.As ussual all comments and questions are welcome
#151 Posted : 05 June 2012 00:20:56
Cool coming on nicely ar.Cool
Yutaro HONMA
#152 Posted : 05 June 2012 13:32:26
Hi Andy!
Thank you for sharing the photos. The edges of the armor plates are very sharp. They looks very attractive.
I notice that you extended the stern side plates, didn't you?
I attach two photos. 1st one is from DeAGOSTINI Japan's original step. Red lines shows the margin of the plate. 2nd one is from the plan of 1/350 the Akagi and red lines shows the plates. It is easy to notice that original plate is shorter than the one of 1/350. I think you are so careful that you have found the mine of DeAGOSTINI Japan.
Best Regards,
Yuraro
#153 Posted : 05 June 2012 17:32:46
BigGrin Thank you Karl and Yaturo for the kind words,Yaturo thanks for pointing out the anomally in the length of the rear armour plate strips but i fitted these as suplied not by extending them,if you fit these from the corect hull former thats where they reach too .It would seem that the rear plates are now supplied longer but the instructions have not changed,it certainly had me scratching my head for a while as the 25mm mark wasnt in the correct place as per the instructions [the end of the armour strip went way past it].
In the end my desision was to fit as supplied as i surmised the armour belts would have reached that far towards the stern to protect the steering mecanisms and it looked right in my eyes.
Heres a few more pic's of the build so far im now back up to date with deliverys and the placment of components so far made are guestimates of there final positions, as ussual all comments and questions are welcome
Yutaro HONMA
#154 Posted : 06 June 2012 13:39:08
Hi Andy!
You are right!BigGrin Your explanation, "The amour plates protect the important mechanisms of the ship" is very logical to be understood. Any one who know this principle do not take the mistake about the amour plates.Cool
Best Regards,
Yutaro
#155 Posted : 07 June 2012 21:09:51
BigGrinThank you Yaturo for the vote of confidence Cool
#156 Posted : 08 June 2012 08:36:56
Hi Andy, I think your build of the Akagi is awesomeBigGrin you should be proud of your excellent work BigGrin Regards MikeThumpUp
#157 Posted : 08 June 2012 22:44:23
Blushing Thank you Mike
that is truely a compliment comming from youCool
#158 Posted : 08 June 2012 23:02:03
Can only ditto that Andy, and nice to see your leaving no stones unturned and taking it to the top level Cool
#159 Posted : 09 June 2012 02:15:27
Blushing Thanks Mr T
for the kind words of encouragement,after being out of modeling for a good while it is truely an enjoyable learning curve making these models an enlightening experience with the comments and help from other people on the forum[even i have learned things from here and i hope iv helped other people do the same].At times i think i bite off more than i can chew trying to achieve what i think is the best i can do,and fail to get the results i want but i guess thats the perfectionist in me and all modelers that want to achieve the best they can.Again thanks to yourself and Mike and everyone else that looks and comments on my efforts its all apreciated
AndyBlushing
#160 Posted : 07 July 2012 11:21:38
Angry Hi All
not much progress todate still waiting for last months issue's,was told by c/s that it was sent out on the 15th and i would recieve by friday just past [6th]well im still waiting,thing is they have taken my cash but refuse to send me out a replacment as the time hasnt elapsed yet.Cursing
On another note after the advice from Yaturo and his recomendations on the build and the discovery that no plans of any sort are provided,iv sent for a set of Miyuki-kia 1/200 blueprints .Yes there 1/200 not 1/250 but close enough for what i need ,this should resolve any issue,s brought to light so i can rectify them to my satisfaction
32 Pages «<678910>»
This page was generated in 0.122 seconds.
