E type screws Options
firefighter
#1 Posted : 27 March 2012 22:28:54
can somebody tell me which are the E type screws to the cockpit base onto the cockpit side as it says in mag 44
scottww86
#2 Posted : 28 March 2012 04:19:36
It might just be me bein a bit daft but I thought in 1 of mags around that issue (couldn't say which without looking) but what the screw type said in the build guide was a different screw to the type mentioned in the "parts included with this issue" part. I know we doña always use the parts from that particular issue but I'm sure it said to use a type E screw for example but the picture showed a different (similar to) type c screw. Id check it against mr T's online build to make sure it's the correct one. I was at sea so didn't have Internet and wham reading that particular issue I got a bit confused!
Besides that, type E are the small black screws, like the ones used to screw most of the rear suspension together!
Enjoy!
firefighter
#3 Posted : 28 March 2012 16:15:33
thanks for that il have a better look
This page was generated in 0.119 seconds.
