Joined: 27/03/2011 Posts: 47 Points: 124 Location: North wales
Putting the damper unit stages 3 and 4 together, middle section of crank is not in correct position when connected to rear supension unit. It is almost upright! Have taken it apart a number of times, gone through each stage of putting together again looking at Tomicks images - all seems same, then when I screw to gearbox and connect suspension up goes the middle crank. Any ideas on where I might be going wrong? Help greatly appreciated - hopefully the images show the problem   Note - obviously not in the correct postion in the images, but even when it is, it's the same
Dave
 Rank: Pro  Groups: Registered
Joined: 05/04/2011 Posts: 266 Points: 784 Location: Essexshire
You may have them handed wrong ie swop them over
Skiddy wrote:You may have them handed wrong ie swop them over Believe it or not, just after I posted this, went back and went through all again, and yes it was the middle carnk giving the problem!!! Feel very much a simpleton at the moment cheers
Dave
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,829 Points: 17,639 Location: ipswich
You've assembled the units incorrectly. If you look at yours, the 'outer' smaller cranks are curving outwards, away from the car centre line. They should be curving inwards, the same as the larger cranks. You need to disassemble them, and fit ALL of the cranks 'curving' in the same direction. You can see this clearly in pictures 4 and 5 on page 13 of issue 44. All the best, Roy.
I did pick up this problem several weeks ago, when I said that the spue that hold said parts should have been numbered,this is the first kit I have made that was not numbered,and thanks to tomicks close ups I was able to sort it right,and got hammered for being a beginner to f1 and didn't know how an f1 car worked.as it happened I was building f1 cars before that kid was born.so just crack on and keep trying,like me to get it right. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Thanks folks - all sorted now numbering the sprues would have been helpful
Dave
