20 Pages «<1112131415>»
Karl's H.M.V Endevour.Part work's with Eaglemoss. Options
#241 Posted : 19 April 2012 13:33:20
week 65. windows,scroll across the top and a couple of moulding pieces to fit this week,not much to say really,'cept I had to file down the window frames to get them in.
#242 Posted : 19 April 2012 14:55:21
Nice detail..
alantait
#243 Posted : 19 April 2012 15:35:22
Hi Karl, although it looks nice, i am not sure about the "painted windows" i have the feeling that i will cut these out and use a Acetate sheet as in the victory. apart from that she is looking a neat ship, keep up the good work.
current builds
#244 Posted : 19 April 2012 17:51:16
hi alan,good luck with the windows,I didn't think that the design would incorporate see through windows too well,as the side windows are also solid lumps of white metal which I presume will the same light blue.Mellow
alantait
#245 Posted : 19 April 2012 18:06:15
Hi Karl, Yes seen the side windows which i have drilled out and filed to shape, i know there is nothing inside such as decks etc. but since i have not yet started the build i will add some deck area. i suppose i am lucky i did not start from the beginning and have stored all the parts so i know most of the pitfalls thanks to yourself and others.
i would expect that you may well have done something similar in hind sight, knowing your fantastic attention to detail.
all the best
current builds
IAN
#246 Posted : 19 April 2012 20:10:48
Hi Karl..
the Endeavour is looking great.,
Best regards,
Ian
Ian
Wish list: Bentley Blower
Silent_Running
#247 Posted : 20 April 2012 12:28:16
Great work Karl! Well done! ThumpUp
#248 Posted : 20 April 2012 13:02:48
that you very much for the comments.they are appreciated Cool
#249 Posted : 10 May 2012 13:43:45
week 68,and a mammoth amount of work,a WHOLE rudder to do.
alantait
#250 Posted : 10 May 2012 17:00:58
Hi Karl, your sarcasms getting better with age, i agree i picked my copy up about 10 minutes ago and couldnt believe what we are doing this week... it will take the whole week to complete this especially if i make cups of tea every half hour or so Flapper . might just plank the rudder to make it last longerLOL
current builds
#251 Posted : 10 May 2012 17:44:25
SARCASM,SARCASM,sarcasm,nawwwwwwwww,for the endeavour that is a lot of work.
The bearded 1
#252 Posted : 11 May 2012 03:06:46
Hi Karl. The Endevour is looking great. I noticed the rudder seems to be made static, don't like this, am going to try to make it a working rudder. Turn the ships wheel, rudder turns (wish me luck on that one) Want more pics and tips.BigGrin
Current builds:
The Victory (of course)
The Endeavour
The Bismarck
Lancaster Bomber
And any model kit that catches my eye
Everything from 1/35 military to Godzilla and anything in between.
Oh and a suit of armour. ( yes real knights armour )
#253 Posted : 11 May 2012 14:53:42
hi bearded 1.I intend to do the same,by using pullys and blocks as the original.also will be adding some other mods,
#254 Posted : 18 May 2012 16:04:49
week 69. the rudder installation this week,started by drilling and filing to let the rudder inthe ship,I found this reasonably easy.
#255 Posted : 18 May 2012 16:05:56
#256 Posted : 18 May 2012 16:07:21
the next part was to drill the top of the rudder for the tiller.
#257 Posted : 18 May 2012 16:12:05
didn't care for the wood supplied or the method of fitting the tiller,reducing the tiller down to 2mm.x2mm. far to weak,so I made another from wallnut 4mm. x4mm.and the used a cocktail stick for the end of the shaft.much better.
#258 Posted : 18 May 2012 16:14:08
http://s909.photobucket....mp;current=IMG_8589.jpg
http://s909.photobucket....mp;current=IMG_8588.jpg
and lastly, fitted the rudder hinges.
#259 Posted : 18 May 2012 16:15:12
#260 Posted : 24 May 2012 16:19:28
week70,and another bumper week this is!78 pieces involved,though you only ONLY
have to fit 6 of them,they are called the breakwater sheets.the bits that hold the spritsail mast.two pieces laminated by three pieces each.ermmmmm can't think of anything else to say.
This page was generated in 0.527 seconds.
