3 Pages <123>
Dedworth Dog's Build Diary Options
dedworthdog
#21 Posted : 25 April 2010 19:51:09
Capt Stedders wrote:
Have you tried dislodging the hull formers with a soft mallet?
Since you have little to lose (if you are already resigned to getting back issues), you might try localised applications of hot water to the joins to soften the glue first. if you are careful, you might just get away with it without warping the false keel.
Good luck - I hope you manage to sort it out.
I did consider using a 12lb sledge hammer to dislodge the formers and an application of naked flame to melt the glue but once the missus heard the swearing all items which coiuld cause harm were hiddenCrying
Follow my build to learn how to make firewood
Capt Stedders
#22 Posted : 25 April 2010 20:00:21
Funny thing was, that after checking up on the bow parts from Issue 1, I noticed that the front bulkhead was no longer square to the bow former (which also seemed to have gone a bit squinty).
Having to separate the parts (even after gluing) wasn't too troublesome with an X-Acto and a bit of firm tapping with a rubber headed mallet. They are now currently clamped firmly between two sheets of heavy glass plate (with wooden offcuts to spread the points of contact).
It doesn't always pay to use too much glue.
Schnellboots on back burner
Tools.
#23 Posted : 26 April 2010 00:20:29
i have had both these problems first i glued in and realised i had droped an almity clanger i got my ribs out but not without snapping them so i had to buy some more keel was ok though BigGrin i also had warped parts the glass press worked for me but i was advised to soak in hot water first dont know what differance it made but flat they are now!!
dedworthdog
#24 Posted : 26 April 2010 15:40:12
I am mighty glad to see I was not the only one to make this mistake, thanks for raising my spirits (a tot of rum maybeDrool )
dedworthdog
#25 Posted : 26 April 2010 16:11:54
Well issue 3&4 arrived today with the "helping hands" magnifier. Next job to check if they are warped. Note to self read everything thrice before glueingCool
Jack Sparrow
#26 Posted : 26 April 2010 16:50:20
Use the magnifier!!LOL LOL LOL LOL Flapper BigGrin
Capt Stedders
#27 Posted : 26 April 2010 18:20:25
Should have gone to Specsavers..
*sorry, couldn't help it - blame Jack Sparrow, he encouraged me.. Blushing
Tools.
Jack Sparrow
#28 Posted : 26 April 2010 19:26:44
I knew i would get the blame for something somewhere!!!!BigGrin Just like home!!LOL LOL
Jack Sparrow
#29 Posted : 26 April 2010 19:28:02
like you needed any encouragment!!!Flapper LOL
Jamie
#30 Posted : 26 April 2010 21:38:38
Move away from the glue pot sir, that's it put it back in the drawer and move away slowly..........Flapper LOL
I wish I were a glow worm,
A glow worm's never glum,
'Cause how can you be grumpy?
When the sun shines out ya bum!!
dedworthdog
#31 Posted : 01 May 2010 16:48:39
OK as I am now going to get a buckshee canon and anchor I thought I would give them a bash. So here is the canon in pictures
First coat of paint
[size=7]I am pleased with the result as it was my first attemptBigGrin
dtgray
#32 Posted : 01 May 2010 16:54:36
Nice work BigGrin
David
Jamie
#33 Posted : 01 May 2010 17:57:42
Looking good ThumpUp
dedworthdog
#34 Posted : 01 May 2010 17:59:44
Ok so here goes the anchor, Despite saying previously that I would follow the instructions precisley and as I have got a buckshee anchor I thought that I would try using white card instead of the string. I am mildly pleased with the result. Also I used a model saw and craft knife to fashion the recesses in the spars for the anchor rather than filing them out.
dedworthdog
#35 Posted : 01 May 2010 18:26:00
The finished cannon
Jamie
#36 Posted : 01 May 2010 19:33:17
Blimey they look a bit of alright Cool
What paint/colour have you used on the cannon wheels?
dedworthdog
#37 Posted : 01 May 2010 19:54:52
The wheels are humbrol acrilic No 63 "sand"
budgie
#38 Posted : 01 May 2010 20:21:07
BigGrin lookin good keep it up will be watching for inspiration
Jamie
#39 Posted : 01 May 2010 20:31:33
Cheers mate Cool
dedworthdog
#40 Posted : 04 May 2010 12:09:31
Ok so what have I learnt from assembling the cannon?
1. Paint wheels before assembly.
2. When trimming axles trim to about 2mm not the 3 as suggested in instructions (Less to file down)
3. Rather than applying glue direct to componants. dispense glue into a plastic milk bottle top and use a cocktail stick to apply glue.
I am still planning to make all the cannons etc in one hit reasons are.
1. Less paint wasted. Each time you stir the pot and clean the brush paint is wasted and whilst the pot is open the paint begins to dry and therefore thicken. (Tight beggar)
2. The various techniques that I develope for each build will not have to be relearnt as it could be months between each cannon.
3. Easier to store parts in the transit packaging
3 Pages <123>
This page was generated in 0.396 seconds.
