Bad panel fit? Options
#1 Posted : 22 April 2012 11:01:04
It does appear, according to the 'Official' DeAg Japanese build, that a bit of 'hacking' is required to get a good panel fit at the rear on the completed model:
http://translate.google....ih%3D744%26prmd%3Dimvns
Like the colour issue, which the link also seems to allude to, Kyosho has a few problems with the kit that I doubt will be any different over here.
The alterations needed to make the parts fit better seem to be quite simple, so I for one will probably incorporate the mods As I go along.
They don't seem to be major, and wouldn't affect any of the kit build even if Kyosho have actually fixed the errors.
Roy.
Warthog
#2 Posted : 22 April 2012 12:40:18
I see this as a positive that we know about this now!! BigGrin .. Alterations can be made without having to "dismantel" the Kit at a later date.. As you all know I have been making my own alterations as I go along and its always part of being a model maker... You can spend 100's of pounds on an Airfix or Tamiya kit only to find that "alterations" need to be made along the way... Something I have accepted for many years.
I'm not saying that everyone should accept this but its part of the modeling world and what makes us a better modeller... it's an art and any kit that is attempted, whether it's £10 or £1000, alterations of some kind will need to be made at some point...
Spence
kryten2b
#3 Posted : 22 April 2012 22:34:10
I can see links to a couple of PDFs to fix engine cowl fit, but the links won't open in google translate - so how do you actually get the fix instructions?
Thanks for the heads-upBigGrin
Well spin my nipple-nuts & send me to Alaska
Current Builds:
McLaren MP4-23Finished
007's Aston Martin DB5Finished
Millennium Falcon
R2-D2
BTTF Delorean (Maybe)
#4 Posted : 22 April 2012 22:42:38
I downloaded the Japanese PDF's as the pictures are fairly self explanatory.
I'm going to try copying and pasting chunks of the text into Babelfish to see if I can translate it.
Slow and laborious, but we'll see......
Roy.
Warthog
#5 Posted : 22 April 2012 22:48:35
Kryten... go to the left hand side when it comes up with "to large to translate" and go to "open original" ... to save... go "file" and "save as"
Spence
This page was generated in 0.263 seconds.
