22 Pages «<1213141516>»
Stefan's build Options
#261 Posted : 23 April 2012 14:13:54
Nice tip matey
Thanks Cool
#262 Posted : 24 April 2012 13:14:41
Hi Stafan.
Fantastic build keep up the good work. nice tip for the cross tree IanBigGrin
StefanDV
#263 Posted : 24 April 2012 16:30:52
Thanks gents,
I'm busy building the fore-mast, but the pictures look so similar to the main mast, I'm not putting them up.
StefanDV
#264 Posted : 26 April 2012 09:20:03
Quick snapshot of my progress to date:
The top gallant fitted to the fore mast. There is still some painting to be done and then the mast will be dressed.
#265 Posted : 26 April 2012 12:51:49
Looks like a damn good job done there Stefan....I'm at about the same stage as you mate...keep the pictures coming...
Drool ThumpUp
StefanDV
#266 Posted : 26 April 2012 15:52:46
Thanks Jonny.
It's a bit of a battle to make enough time to do it, but a little every evening after the boys have been put to bed does the trick for me.
StefanDV
#267 Posted : 02 May 2012 10:05:49
The foremast painted and being dressed:
Both masts fitted (not glued) to the hull
Overall view
Fore yard being shaped
Fore yard painted
Fore yard and studding sail booms
#268 Posted : 02 May 2012 10:59:51
Looking real great Stefan!! ThumpUp See that the captain is ready to repel all boarders!! LOL
#269 Posted : 02 May 2012 11:44:36
Good looking job there, Stefan, you are coming on in leaps and bounds. You can be proud of what you have achieved so far.
#270 Posted : 02 May 2012 11:56:05
Hi Stefan,
Great work, love the detailBigGrin Regards Mike
StefanDV
#271 Posted : 02 May 2012 12:37:13
Thanks Gents!
Yes Jonny, through the years he has been known by many names. Diablo Gato, The Furry Lover, Chupa Cabra, Frisky Two Times and then The Gingerhead man. Don't know how he commandeered the vessel :o
#272 Posted : 02 May 2012 16:11:55
Hi Stefan,
Super build Stefan,all that hard work has payed off,please keep sending pictures.
Regards tf64.
StefanDV
#273 Posted : 03 May 2012 14:43:50
Thanks tf64!
I'm rolling on the fore main yard assembly, got all the sub-assemblies done:
The blocks
The wires
And then the assembly process:
And the sorting out of unforeseen issues :(
#274 Posted : 03 May 2012 22:00:02
Hi Stefan,
Fore main yard assembly is looking good,nice work,those sub-assemblies look hard work how's your fingers bet they sore.
Not up to that stage yet,keep sending Stefan.
Regards tf64.
Gerrit
#275 Posted : 04 May 2012 06:56:14
Awesome work Stefan Keep up the good work
StefanDV
#276 Posted : 04 May 2012 09:56:02
Thanks tf64 & Gerrit
tf64: I used the rest of the wire that was supplied with the main yard which was a little tougher to wrap, but did not break at all - normal needle-nose pliers. The wire which was supplied with the fore yard was softer and more pliable, but I broke 1 while forming it and another when I fitted it to the yard Cursing
I drilled another hole right next to the broken shaft and fitted another part. I'm going to ask for a replacement issue as issue 71 was short 1 of the end-irons anyway.
Cutting the short pieces for the Main top yard
Middle part of the main top yard glued in place
The fore yard being dressed:
#277 Posted : 04 May 2012 12:05:53
Nice and neat job there Stefan. Looks like I might need to source some better wire locally as I should be starting my masts this weekend.
StefanDV
#278 Posted : 04 May 2012 12:17:55
Thanks Hans.
It may be helpful, even though there is more than enough wire supplied.
Some folk annealed their wire by heating it (may on the braai?) and then letting it cool. It would be great if you can get enough wire to finish all the yards in one go.
Castos
#279 Posted : 04 May 2012 14:05:50
Hi Stefan
I am enjoying your build. Speaking of wire - go and take a look at the Craft shops that sell beads to make jewelry, they have a lot of brass wire in different sizes, I found some at the china mall in JHB.
Cheers
Current Build: HMS Victory
Built: HMS Bounty
Next Build: Sovereign of the Seas Started collecting. Redrawing of plans for Santisima Trinidad for a scratchbuild. Santisima Trinidad - waiting for launch.
#280 Posted : 04 May 2012 14:27:49
Thanks Stefan. I recall there was thread about it. Castos has also put another idea through (thanks Castos), as I am in JHb I will go and have a look anyway. You are right, there probably is suficient wire, but if the quality is suspect it will do no harm in trying to source something better. After all the money spent so far anyway, it will be worth it.
This page was generated in 0.199 seconds.
