13 Pages «<910111213>
Colour change in parts OMG Options
only1ianuk
#201 Posted : 24 April 2012 14:43:20
I've been sent issues, 1,2,3,4,5,14,15,16,17. The colours are unchanged. After seeing Roys post called and requested 6 & 7 also. Will hold onto these until Admin come back with a response.
If they come back with nothing then i will give Spencers "Pledge Klear" a go. Worst case scenario, Spencer has offered to do everyones for them which is very kind of him! Flapper
scotty2hotty
#202 Posted : 24 April 2012 14:45:22
Just to confirm. Which issues do I need to reorder?
firefighter
#203 Posted : 24 April 2012 14:46:39
Iv sprayed the front and rear wing left i while to dry and YES they look red but not quite the same as the side cowls but better than orange as they where Confused not sure what do you all think guys
only1ianuk
#204 Posted : 24 April 2012 14:51:49
Hi Scotty,
The issues required are 1,2,3,4,5,6,7,14,15 & 16. I think that covers them all. They sent me 17 as well but not quite sure why?Confused
only1ianuk
#205 Posted : 24 April 2012 14:53:50
They look good, although the image is a little blurry to see the full effect and how shiney they are!
A Question though, how do you get the real good shine like car laquer?
firefighter
#206 Posted : 24 April 2012 15:20:06
If you look at my images one of the as got a tin of spray thats all i used just did a few thin coats about 4 if i remember but let each coat dry before the next took my time and a steady hand
#207 Posted : 24 April 2012 15:59:17
This is my 'experimental' front wing.
2 coats of Halfords clear lacquer - 15 mins between coats.
I'm happy with the finish. Forgive the naff picture - cheapo camera.
The wing is now very smooth and glossy although the pic doesn't show it well.
I want red side pods!!!!!!
Roy.
only1ianuk
#208 Posted : 24 April 2012 16:57:34
Hi Roy,
I'm a real novice at spray paint but did you use anything else to get the shine or litterly just spray?
Thanks
Ian
Skiddy
#209 Posted : 24 April 2012 16:57:50
Skiddy wrote:
As above....just opened issue 46 to fit the sidepod cowls and they are a glossier and brighter red to all the other parts ( same colour ).
Now....are all the other parts wrong or right ??
The previous red's are a semi matt finish and this one is much better but I don't want a two colour red car Cursing.
This is the first real problem I have had and it ain't a small one.
Admin...Tommick, advise please....do I bin the kit or are you going to give me some reassurance that this is not the real colour ? HELP !!
Hmmm....that's what it's all about Confused
#210 Posted : 24 April 2012 17:16:17
only1ianuk wrote:
Hi Roy,
Thanks
Ian
It's just spray straight from the can.
2 light coats at around 18" distance.
The spray wasn't heavy enough to look 'smooth' on the panel - if it is, you've put too much on.
It should look very slightly 'dimpled' - as if you haven't sprayed quite enough.
Don't worry - it will 'flatten' after a few minutes, and then dry out.
Remember, if your lacquer still isn't quite smooth enough, you can always give it another coat 15-20 mins later.
If you aim for a glassy finish straight from the can, IT WILL RUN!
Several light coats will give a great gloss.
Let it dry for a few days then polish it with Micromesh.
That's what I will do as my wing ISN'T glossy enough yet!
Roy.
S2ksean
#211 Posted : 24 April 2012 17:39:43
Just spoke to customer service and there gonna send me issues 1 3 and 7 to replace the old parts.
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#212 Posted : 24 April 2012 17:43:31
For the front, you need 1, 2, 3, 5, 6 & 7......
Roy.
S2ksean
#213 Posted : 24 April 2012 17:44:44
Il cal them back and see what they say. Thanks
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
only1ianuk
#214 Posted : 24 April 2012 17:57:32
Thanks Roy,
Will prob give it a go. But will wait and see what Deag say first as they might want the parts back before replacing with "correct" ones if this happens?!
S2ksean
#215 Posted : 24 April 2012 18:02:14
Just Tryed to call again and got cut off after five minutes then called again and got cut off after 8 minutes I'm not happy and it's an 0845 number.
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#216 Posted : 24 April 2012 18:37:45
Both times I called was around 10.30 mornings.
They answered in around 30 seconds.
I'd guess this time of the day, everyone else rings as that's when they're home from work so the switchboard is frantic.
BTW.... They NEVER asked me for any bits back.
Roy.
S2ksean
#217 Posted : 24 April 2012 18:40:40
Same here
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
driving4life
#218 Posted : 25 April 2012 01:23:27
Rank: Amateur Level 1
Roy.
That has made a hugh difference from what I can tell. Did you also have to apply the lacquer to the silver parts or just the bits where it is meant to be red ?
Cheers
Tintin666
#219 Posted : 25 April 2012 02:24:11
I too am being sent these parts,I tried calling them again as I noticed not all parts were covered to redo the wing but as yet no joy, but I have been cut off 8 times now. I was also told originally I'd be updated by email re' rear wing parts but again nothing as of yet nothing. Anyone else know anymore?
Current builds:
McLaren MP4-23 1/8
Aston Martin DB5 1/8
#220 Posted : 25 April 2012 09:16:08
With regards my red wing:
I only lacquered the red parts, before assembling them. (see my message above for how I did it)
With regards getting hold of customer services, also see my message above - try ringing mid-morning, 10.00-11.30.
I've not had to wait more than a minute.
Roy.
This page was generated in 3.240 seconds.
