 Rank: Pro  Groups: Registered
Joined: 01/07/2011 Posts: 383 Points: 1,194 Location: Birmingham
I've been sent issues, 1,2,3,4,5,14,15,16,17. The colours are unchanged. After seeing Roys post called and requested 6 & 7 also. Will hold onto these until Admin come back with a response. If they come back with nothing then i will give Spencers "Pledge Klear" a go. Worst case scenario, Spencer has offered to do everyones for them which is very kind of him!
Joined: 18/03/2011 Posts: 203 Points: 620 Location: Surrey
Just to confirm. Which issues do I need to reorder?
Joined: 20/12/2011 Posts: 134 Points: 384 Location: barnoldswick
Iv sprayed the front and rear wing left i while to dry and YES they look red but not quite the same as the side cowls but better than orange as they where  not sure what do you all think guys
Hi Scotty, The issues required are 1,2,3,4,5,6,7,14,15 & 16. I think that covers them all. They sent me 17 as well but not quite sure why?
firefighter wrote:Iv sprayed the front and rear wing left i while to dry and YES they look red but not quite the same as the side cowls but better than orange as they where  not sure what do you all think guys They look good, although the image is a little blurry to see the full effect and how shiney they are! A Question though, how do you get the real good shine like car laquer?
only1ianuk wrote:firefighter wrote:Iv sprayed the front and rear wing left i while to dry and YES they look red but not quite the same as the side cowls but better than orange as they where  not sure what do you all think guys They look good, although the image is a little blurry to see the full effect and how shiney they are! A Question though, how do you get the real good shine like car laquer? If you look at my images one of the as got a tin of spray thats all i used just did a few thin coats about 4 if i remember but let each coat dry before the next took my time and a steady hand
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,830 Points: 17,642 Location: ipswich
This is my 'experimental' front wing. 2 coats of Halfords clear lacquer - 15 mins between coats. I'm happy with the finish. Forgive the naff picture - cheapo camera. The wing is now very smooth and glossy although the pic doesn't show it well. I want red side pods!!!!!! Roy. roymattblack attached the following image(s):
Hi Roy, I'm a real novice at spray paint but did you use anything else to get the shine or litterly just spray? Thanks Ian
Joined: 05/04/2011 Posts: 266 Points: 784 Location: Essexshire
Skiddy wrote:As above....just opened issue 46 to fit the sidepod cowls and they are a glossier and brighter red to all the other parts ( same colour ). Now....are all the other parts wrong or right ?? The previous red's are a semi matt finish and this one is much better but I don't want a two colour red car  . This is the first real problem I have had and it ain't a small one. Admin...Tommick, advise please....do I bin the kit or are you going to give me some reassurance that this is not the real colour ? HELP !! Hmmm....that's what it's all about
only1ianuk wrote:Hi Roy, I'm a real novice at spray paint but did you use anything else to get the shine or litterly just spray? Thanks Ian It's just spray straight from the can. 2 light coats at around 18" distance. The spray wasn't heavy enough to look 'smooth' on the panel - if it is, you've put too much on. It should look very slightly 'dimpled' - as if you haven't sprayed quite enough. Don't worry - it will 'flatten' after a few minutes, and then dry out. Remember, if your lacquer still isn't quite smooth enough, you can always give it another coat 15-20 mins later. If you aim for a glassy finish straight from the can, IT WILL RUN! Several light coats will give a great gloss. Let it dry for a few days then polish it with Micromesh. That's what I will do as my wing ISN'T glossy enough yet! Roy.
Joined: 11/05/2011 Posts: 766 Points: 2,128 Location: Dagenham
Just spoke to customer service and there gonna send me issues 1 3 and 7 to replace the old parts. CURRENT BUILDS
Mclaren MP4-23 Ford 1/12 Shelby Mustang GT500 2010 HMS Pandora
S2ksean wrote:Just spoke to customer service and there gonna send me issues 1 3 and 7 to replace the old parts. For the front, you need 1, 2, 3, 5, 6 & 7...... Roy.
Il cal them back and see what they say. Thanks CURRENT BUILDS
Thanks Roy,
Will prob give it a go. But will wait and see what Deag say first as they might want the parts back before replacing with "correct" ones if this happens?!
Just Tryed to call again and got cut off after five minutes then called again and got cut off after 8 minutes I'm not happy and it's an 0845 number. CURRENT BUILDS
Both times I called was around 10.30 mornings. They answered in around 30 seconds. I'd guess this time of the day, everyone else rings as that's when they're home from work so the switchboard is frantic. BTW.... They NEVER asked me for any bits back. Roy.
Same here CURRENT BUILDS
roymattblack wrote:This is my 'experimental' front wing. 2 coats of Halfords clear lacquer - 15 mins between coats. I'm happy with the finish. Forgive the naff picture - cheapo camera. The wing is now very smooth and glossy although the pic doesn't show it well. I want red side pods!!!!!! Roy. That has made a hugh difference from what I can tell. Did you also have to apply the lacquer to the silver parts or just the bits where it is meant to be red ? Cheers
S2ksean wrote:Just spoke to customer service and there gonna send me issues 1 3 and 7 to replace the old parts. I too am being sent these parts,I tried calling them again as I noticed not all parts were covered to redo the wing but as yet no joy, but I have been cut off 8 times now. I was also told originally I'd be updated by email re' rear wing parts but again nothing as of yet nothing. Anyone else know anymore? Current builds: McLaren MP4-23 1/8 Aston Martin DB5 1/8
With regards my red wing: I only lacquered the red parts, before assembling them. (see my message above for how I did it)
With regards getting hold of customer services, also see my message above - try ringing mid-morning, 10.00-11.30. I've not had to wait more than a minute. Roy.
