56 Pages «<2930313233>»
MWG build diary of the mighty Hood Options
#601 Posted : 28 April 2012 01:20:35
Thank you for your nice comments IanBigGrin Regards Mike
#602 Posted : 28 April 2012 19:41:52
ISSUES 33 and 34
Hi Team, I have nearly finished the second planking, only the base of the Hull to go, this will be straight forward as putting a bevel on the planks is not required because it is a flat surface and we do not need as many pins.In issue 34 we received more planks fo the second planking.
Questions and comments welcomeBigGrin
Regards Mike
#603 Posted : 28 April 2012 21:43:34
BigGrin Looking the bizz now MikeCool
#604 Posted : 29 April 2012 13:52:59
Thanks AndyBigGrin I will finish the second planking today will post more photos Regards Mike
#605 Posted : 29 April 2012 20:10:21
ISSUE 34
Well team I am up to and completed issue 34, I have applied the second planking on the ship and it is finished, here are some photos half way throughBigGrin :-
#606 Posted : 29 April 2012 20:15:31
ISSUE 34
Here are the photos of the ship with its completed second planking.
Please note I have started to fill all the pin holes with Ronseal wood filler, I have not yet started to sand the HullBigGrin Questions and comments welcomeBigGrin Regards Mike
#607 Posted : 29 April 2012 20:26:25
Wow!! Looking great mate!! Drool ThumpUp
#608 Posted : 30 April 2012 08:39:09
Thank you JonnyBigGrin Regards Mike
#609 Posted : 02 May 2012 11:57:28
ISSUE 35
Well team this week we received some etched brass:-
#610 Posted : 02 May 2012 12:00:39
ISSUE 35
The first Job is to seal the wood where we will be fitting the Brass, I prefer to use sanding sealer( please use outside and wear a mask:-
#611 Posted : 02 May 2012 12:03:33
ISSUE 35
When the sealer is dry sand the wood to take off the raised grain ( I like to use emery nail files:-
#612 Posted : 02 May 2012 12:10:14
ISSUE 35
These are the tools and adhesives I am using:
A metal file to remove the brass burrs.
A scalpel to cut the brass from the fret
Superglue Loctite ultra gel is good it contains rubber and will not go brittle overtime, this is for sticking brass to brass.
Evo stick Serious Glue to fit the Brass parts to the wood. there are no fumes with this glue and you have 3 mins to position your part. :-
#613 Posted : 02 May 2012 12:13:09
ISSUE 35
Start by cutting the brass parts from the fret and file off the burrs where they were joined to the fret:-
#614 Posted : 02 May 2012 12:18:41
ISSUE 35
Now stick the doors ( the right way round) to the brass panels:-
And the portholes
#615 Posted : 02 May 2012 12:26:08
ISSUE 35
Next job is to bend the parts which need it using a straight edge:-
Please not I believe the is a misprint on page 140 visual 7 the instruction call fo you to bend part 138 to 45 degrees, I feel this should be 75 degrees as in visual 10 part 139, in any event I have bent both parts to 75 degrees and they fit.
#616 Posted : 02 May 2012 12:33:13
ISSUE 35
Here we have all the parts fitted with a little help from some clamps:-
#617 Posted : 02 May 2012 12:38:10
ISSUE 35
And these are the photos of the finished build this weekBigGrin
Comments and questions welcome
Regards Mike
StefanDV
#618 Posted : 02 May 2012 13:36:53
Well done Mike, your build is looking splendid. Keep the pics coming.
#619 Posted : 02 May 2012 16:21:07
Most interesting build there, Mike. Looks great. Looks like it could be another one for my collection.
#620 Posted : 02 May 2012 18:54:20
Thank you Stefan and Hans for your kind commentsBigGrin Regards Mike
This page was generated in 1.353 seconds.
