Aaaaha!!! Thanks MR.T. I can forget about re-ordering another launch and look forward to issue 109 instead...Great news!!
 Rank: Pro  Groups: Registered
Joined: 25/04/2011 Posts: 165 Points: 471 Location: Glossop
Tomick wrote:Hot off the press....
Issue 109 contains parts to build the 18ft Cutter, which is the smallest of the ships boats, and is constructed on similar lines to the previously supplied 34ft Launch, this issue also contains the parts which make up the Figurehead. Thanks for the Info Mr T First Build HMS Victory and HMS Endeavour Also Krick steam boat "Victoria" Cheers Ivan (Ordinary Seaman) http://www.old-glossop.com
Son of Bulwark wrote:Hi Shipmates! We know what is to come up to issue 106, thanks to Tomicks Official Build Diary, this will leave 14 issues that we don't know about. In these 14 issues we have to finish the dummy guns, fit the rest of the sails, finish the rest of the rigging, make another anchor & fitting the 4 anchors, the ship’s crew?, the flags, get the part to make the removable gun deck diorama and some other small part to finish. That’s a lot to fit into 14 issues, the extra boats are starting to look unlikely to appear! there has been no word from admin about the other boats. So it looks like we only get the 1 boat, I hope I'm wrong! or I'll have to make some to finish the ship. Darron If you goto the Italian Deagabout 2/3 down the page you will see that dragocombat has fitted the supports for 4 boats. First Build HMS Victory and HMS Endeavour Also Krick steam boat "Victoria" Cheers Ivan (Ordinary Seaman) http://www.old-glossop.com
The hull of the 28ft Pinnace is built at 115
Its looking like the quarter davits will be installed at 116, where you'll have the option of fitting them in their vertical (stowed) position, or in their (ready for use) lowered position.
At the battle of Trafalgar, the quarter davit boats (25ft cutter's), were not hanging from the davits.
correct me if I am wrong but at Trafalgar I think the boats were towed behind ready for survivors etc “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
jase wrote:correct me if I am wrong but at Trafalgar I think the boats were towed behind ready for survivors etc Hi Jase, you are right...I received this e.mail from Andrew Baines: Curator of HMS Victory: Thank you for your email. I can confirm that Victory’s Quarter Davits were present at the Battle of Trafalgar and, as you say, the boats from them were towed behind the ship. The remaining ship’s boats were housed in their usual position, on the skid beams in the waist, for the duration of the battle. On the subject of the stern davits, there is some uncertainty as to whether or not they were present at Trafalgar. In completing the ship’s restoration in 2005, these davits were removed, reflecting the most up-to-date research which suggested they were not in the ship in October 1805.
So, I shall be leaving the Victory's boats off, but on display behind the model  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
jonny7england wrote:jase wrote:correct me if I am wrong but at Trafalgar I think the boats were towed behind ready for survivors etc Hi Jase, you are right...I received this e.mail from Andrew Baines: Curator of HMS Victory: Thank you for your email. I can confirm that Victory’s Quarter Davits were present at the Battle of Trafalgar and, as you say, the boats from them were towed behind the ship. The remaining ship’s boats were housed in their usual position, on the skid beams in the waist, for the duration of the battle. On the subject of the stern davits, there is some uncertainty as to whether or not they were present at Trafalgar. In completing the ship’s restoration in 2005, these davits were removed, reflecting the most up-to-date research which suggested they were not in the ship in October 1805.
So, I shall be leaving the Victory's boats off, but on display behind the model  Thanks for that. I guess it all depends how you want to display your model and i think having the boats displayed seperatly would look effective. I am thinking of displaying the ship prior to battle so I can have boats mounted on ship and not have to cover the sky light on the poop deck etc. interesting comment on the Davits I think I may leave off the stern davits and leav on the others. “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Jase and Jonny If the 25ft Cutters are not included I have sourced a great set and in scale  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
An ex-Victory curator (Tim Goodwin) has noted the following within one of his Victory books:
"According to Midshipman Rivers' journal and the carpenter's expenses (held at the Royal Naval Museum), when Victory went into battle at Trafalgar, the Sea boats, hanging on the davits, were lowered and towed astern. Rarely would all boats be lowered before battle, owing to the time required to remove them from the ship."
The parts for the final ship's boat (32ft Admirals Barge), are supplied in issue 118 and is completed in 119, and is another plank-on-frame build.
Hi Team Looks like we are not going to receive the two ships boats (cutters) that hung from the davits or were trailed behind. I have a source for these in 1/84 scale if any one is interested please PM me Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Guest (8)
