56 Pages «<3031323334>»
MWG build diary of the mighty Hood Options
#621 Posted : 03 May 2012 14:42:38
Hi mike.
Nice clean finsh to your hull. well done on the first of many brass bulkhead walls, they get even fiddler when you have to stick doors , ventilater covers and other bits to the bulkheads.
are the portholes drilled into the wood to give them depth.
looking fantastic keep up the good work.
Ian Cool
#622 Posted : 03 May 2012 20:22:26
Thank you Ian for your kind commentsBigGrin Regards Mike
#623 Posted : 03 May 2012 20:52:11
BigGrin Looks like loads of etch to come yummyDrool , looking great MikeCool
#624 Posted : 04 May 2012 08:10:09
Hi Andy, I must say it makes a change from all that plankingBlink Its quiet refreshingBigGrin Regards Mike
#625 Posted : 10 May 2012 10:00:29
ISSUE 36
Well Team I was out bright and early this morning (06:30hrs)and got right down to fitting the parts this week.
I will not go through all the preperation stages, you will be able to pick them up on my build at ISSUE 35
This is what we received today:-
#626 Posted : 10 May 2012 10:03:08
ISSUE 36
I cut out the brass parts with a scalpel, then filed the Brass etch where the parts were attached to the fret:-
#627 Posted : 10 May 2012 10:07:36
ISSUE 36
Then I attached the doors to the brass, using super glue gel, and making sure the hinges were on the correct side.
Then I bent the brass corner piece at 90 degrees.
#628 Posted : 10 May 2012 10:12:38
ISSUE 36
Finaly I stuck the piece`s to the superstructure, in the correct position, using my prefered adhesive (evo stick serious glue)
Remember I have treated the superstructure with sanding sealer for a better bond.BigGrin
Thats all for this week questions and comments welcomeBigGrin
Kind regards
Mike
Gaz
#629 Posted : 10 May 2012 13:54:49
Hi Mike,
Your hood's looking great. Can ask how are you bending the etch parts? I have seen photo etch pliers for sale for around £25 and didn't know if these are a good idea or not. Your input would be greatly appreciated.
Gareth
#630 Posted : 10 May 2012 14:03:45
Hi Gareth, thank you for your question.
I am not using any special tool just two steel rule straight edges (one on the fold and one behind) to create the bend.
Also I have used the edge of the white conti board you can see in the photos.
I hope that helps. Thank you for your nice commentsBigGrin Regards Mike
#631 Posted : 10 May 2012 14:56:27
Comming along nicely mike.
look forward to the next installment Ian.Cool
harty
#632 Posted : 10 May 2012 14:57:07
It just goes to show that you can spend what ever you want up to a small fortune on tools but some of the simplest and cheapest are at hand and will do the job.BigGrin
#633 Posted : 10 May 2012 15:01:15
BigGrinThank you Ian for your nice commentBigGrin Regards Mike
#634 Posted : 10 May 2012 15:02:51
You are right HartyBigGrin What did we do before all those fancy tools? regards Mike
#635 Posted : 10 May 2012 23:38:26
Hi Mike,
Well done Mike this will look good when finished.
Reg-tf64.
#636 Posted : 11 May 2012 10:08:19
Hi Trev, thanks for your nice commentsBigGrin Regards Mike
Jesus-Belzheim
#637 Posted : 11 May 2012 17:29:42
Hi Mike
I read your Building diary of the Hood,
And it looks very good ThumpUp
Keep up the good work BigGrin
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#638 Posted : 11 May 2012 18:27:22
Hi Peter Thank you for your nice commentsBigGrin Regards Mike
S2ksean
#639 Posted : 11 May 2012 20:14:30
Looks great so far mate
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#640 Posted : 12 May 2012 11:57:27
Hi Sean thanks for your commentsBigGrin how is your build going?Regards Mike
Guest (11)
This page was generated in 0.350 seconds.
