22 Pages «<1314151617>»
Stefan's build Options
StefanDV
#281 Posted : 04 May 2012 16:26:41
Thanks Castos & Hans. I'm already spending the money with DeAgostini (Jacklin), so I'll keep asking for replacement issues until the quality is up to scratch ;)
#282 Posted : 07 May 2012 12:32:32
Agree with you in the most parts, Stefan. We are already paying anyway.
StefanDV
#283 Posted : 07 May 2012 17:13:30
Completed main topmast yard:
Fore topmast yard under construction:
I'm fitting the bands (0.25mm thread) using superglue. It makes the thread hard, but I get a much better fit than tying the knots.
#284 Posted : 16 May 2012 13:04:07
Hi stefan.
Your yards are looking fantastic nice clean work. Ian BigGrin
StefanDV
#285 Posted : 16 May 2012 16:34:15
Thanks so much Ian!
I'm still busy constructing the topgalllant yards:
And to ensure nothing gets lost (and because I can BigGrin ) I tied the yards to the masts with household twine
#286 Posted : 16 May 2012 16:50:45
Nifty piece of work there Stefan...Good job done!! Just completed the yards myself...keep the pics coming mate...Wink ThumpUp
#287 Posted : 16 May 2012 18:18:22
Hi Stefan your build is superbBigGrin Regards Mike
Jesus-Belzheim
#288 Posted : 17 May 2012 05:55:14
Hi Stefan
Your Victory is looking very good ThumpUp
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#289 Posted : 17 May 2012 11:45:12
Stefan, your masts and components are looking great. I am busy with mine as well, it is just taking so much time waitng for the varnish to dry............... holding up the works. but it is great to look at yours and see how grand she is beginning to look.
StefanDV
#290 Posted : 17 May 2012 15:02:19
Thanks so much for taking the time to look at my build dairy gentlemen, and to leave a comment - much appreciated!
I'm just doing a little in the evening, the paint and glue needs time to dry!
This is a close-up of the results I'm achieving with super-gluing the thread to the middle of the yards.
Steps:
1. Give the yard the 1st coat of paint.
2. Place a drop of superglue on a work-surface (that you won't accidentally drag a body part/ Magazine /Tool /Victory part through)
3. Place the Yard on the plan
4. Gently dip the end of the thread in the superglue and place in the correct place as per the plan.
5. Hold the thread until it doesn't move any more (10s)
6. Cut the thread long enough so that it will wrap around the Yard
7. Repeat for all threads
8. Starting from the first thread, wrap the thread around the yard and glue in place with a small drop of superglue.
9. After the glue has dried, cut off any excess.
10. with a small file, file off the superglue that spread onto the wood.
11. repaint
The completed main topgallant yard
Cutting away of the ribs of the cutaway
#291 Posted : 18 May 2012 14:53:29
Hi stefan.
looking fantastic. great tip for the yard ropes Ian.Cool
#292 Posted : 20 May 2012 21:36:32
Nice neat job matey
StefanDV
#293 Posted : 21 May 2012 12:11:41
StefanDV
#294 Posted : 25 May 2012 10:00:05
Well, I'm working through issue 74 now. There are still some work outstanding on finishing off the fore topmast, but I have to wait for the replacement issue.
Channel moulding fitted
Had to drink a fine bottle of Pinotage to get the lead that will go on top of the canopy, but it was a sacrifice I was willing to make (and will do again if there is anything wrong with the covering. BigGrin
The lead super-glued to the Entry port canopy top, and the Entry port glued to the hull. Little bit of touch up needed and the gold detail still needs to be done.
The way the shadows fall make the port appear lopsided on the photo, but it is perfectly square.
I found that using the little jig I made to hold the wriggles in place when marking and cutting the Wales came in very handy to glue them in place as well. (The right-most wriggle on this picture has since been centered properly)
Port Stern view
View from the port bow
#295 Posted : 25 May 2012 14:27:50
Good clean build there Stefan. Good lines. It is obvious that you take great pride in what you do, so well done.
StefanDV
#296 Posted : 26 May 2012 09:44:00
Thanks so much for your kind comments Hans!
#297 Posted : 26 May 2012 11:41:25
Hi Stefan your build is really coming togetherBigGrin I like your attention to detailBigGrin Regards Mike
#298 Posted : 26 May 2012 13:45:34
First class Stefan!! ThumpUp
StefanDV
#299 Posted : 28 May 2012 09:49:02
Thanks Mike & Jonny!
Got some work done on the Side ladders over the weekend:
Also a nice surprise waiting for me at the post-office on Saturday!
#300 Posted : 28 May 2012 10:28:16
Looking good Stefan...Love
This page was generated in 0.362 seconds.
