12 Pages <12345>»
tf64build Options
#41 Posted : 07 May 2012 20:04:12
Hi Trev, your buid looks greatBigGrin Good stuffBigGrin Regards Mike
#42 Posted : 07 May 2012 20:14:07
Astonishing Trev Cool
Son of Bulwark
#43 Posted : 07 May 2012 21:11:23
Hi Trev! Love
The detailed work you're doing makes me DROOOOOOOOL!Drool Drool Drool Drool
Well Done TREV!
Darron
harty
#44 Posted : 07 May 2012 23:25:39
very nicely done and great detailBigGrin Cool Love
#45 Posted : 08 May 2012 08:44:40
Some absolutely brilliant work there Trev. She is looking real grand. Keep it up
Jesus-Belzheim
#46 Posted : 08 May 2012 18:57:56
Hi Trev
That`s a great detailwork you`re doing here ThumpUp
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
Castos
#47 Posted : 09 May 2012 13:20:04
Nice work Trev.
May I get permission use your ideas for the wardroom?
Andre
Current Build: HMS Victory
Built: HMS Bounty
Next Build: Sovereign of the Seas Started collecting. Redrawing of plans for Santisima Trinidad for a scratchbuild. Santisima Trinidad - waiting for launch.
#48 Posted : 09 May 2012 16:48:12
Hi Trev as usual great workBigGrin Regards Mike
#49 Posted : 09 May 2012 18:16:49
Hello Shipmates,
Thank you all for veiwing my posts,I know it has been some time since my last post.The problem I have is that I keep having new ideas about my build, and then start to plan my thoughts in my mind, this build will be a long one.
Hello Castos and welcome to the forum,you will find craftsmen on this site and only to pleased to help if you need it.
Castos you may have my permission to copy my build on the Wardroom,this is not a true representation but ok for me.You will find that a pair of tweezers and a magnifying glass will be must.I built my wardroom from scrap wood, and the food and bowls from Fimo clay,most of the measurements I made up to fit the part,but I would do it again because I feel my ship will have some thing inside as well as outside.
Regards Trev.
saintsman123
#50 Posted : 09 May 2012 20:11:41
great work. have you any bigger pic's of the ward room, as it's really good.
Come on you Jimmies
#51 Posted : 10 May 2012 20:06:24
Hi Saintsman,
Thank you for your interest,have a look at at this picture of the wardroom I hope it is large enough if you click on the other pictures in my post they should go full size.
Regards tf64.
#52 Posted : 11 May 2012 10:31:39
Hi Trev,
That wardroom is fantasticDrool Well done youBigGrin Regards Mike
Bameraam
#53 Posted : 11 May 2012 11:43:30
That detail... , this is really the bomb in modelling!
Great craftswork!
#54 Posted : 19 August 2012 00:16:08
Hi Shipmates,
A long time since the last post,well I have finish the middle deck planking,but the stairs I found that in my case the wood suplied to week to model with,the only way was to make a copy of the stairs in hard wood.
The pictures will show how I copyed the stairs.
Thanks for looking.
Regards Trev.
#55 Posted : 19 August 2012 00:40:19
BigGrin Hi tf64
nice work on the stairs,strange how sometimes supplied parts are useless for the intended application
#56 Posted : 19 August 2012 11:26:32
Hi Andy,
Thanks for looking.
Best Regards Trev.
#57 Posted : 31 August 2012 11:22:52
Hi Shipmates,
The picture in my last post shows the Companion ways and Ladders.As you can see I had a small problem with the ladders,but I cannot understand the look of the long brass eyebolts,is this how it was,I cannot find ref to it.So I have decided to make my own using 2mm dowel,with the blank I turned to shape,drilled,and stained,although this project in not completed yet I have posted a few pictures.
2mm Blank.
Turning to Shape.
Drilling rope holes.
Size 10mm 2mm.
Fitting wire to base.
Drilling grating.
A brown thread will be spun onto 0.50 wire and insterted into each hole.
Thanks for your time.
Regards Trev.
#58 Posted : 31 August 2012 11:35:20
Hi Trev Beautiful workDrool Regards Mike
mark 2
#59 Posted : 31 August 2012 20:07:24
Hi Trev.
Absolutly stunning DroolBigGrin.
Thanks for showing how it was done.
Best regards my friend.
#60 Posted : 31 August 2012 21:01:31
A great enhancement Trev Cool
12 Pages <12345>»
This page was generated in 1.429 seconds.
