Hi Trev, your buid looks great  Good stuff  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Astonishing Trev
Hi Trev! The detailed work you're doing makes me DROOOOOOOOL! Well Done TREV! Darron
Some absolutely brilliant work there Trev. She is looking real grand. Keep it up Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Hi Trev That`s a great detailwork you`re doing here
 Rank: Pro  Groups: Registered
Joined: 05/09/2010 Posts: 123 Points: 358 Location: Valhalla, Pretoria
Nice work Trev. May I get permission use your ideas for the wardroom? Andre Current Build: HMS Victory
Built: HMS Bounty
Next Build: Sovereign of the Seas Started collecting. Redrawing of plans for Santisima Trinidad for a scratchbuild. Santisima Trinidad - waiting for launch.
Hi Trev as usual great work  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hello Shipmates, Thank you all for veiwing my posts,I know it has been some time since my last post.The problem I have is that I keep having new ideas about my build, and then start to plan my thoughts in my mind, this build will be a long one. Hello Castos and welcome to the forum,you will find craftsmen on this site and only to pleased to help if you need it. Castos you may have my permission to copy my build on the Wardroom,this is not a true representation but ok for me.You will find that a pair of tweezers and a magnifying glass will be must.I built my wardroom from scrap wood, and the food and bowls from Fimo clay,most of the measurements I made up to fit the part,but I would do it again because I feel my ship will have some thing inside as well as outside. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Joined: 30/01/2011 Posts: 865 Points: 2,410 Location: Cambs
great work. have you any bigger pic's of the ward room, as it's really good. Come on you Jimmies
Hi Saintsman, Thank you for your interest,have a look at at this picture of the wardroom I hope it is large enough if you click on the other pictures in my post they should go full size. Regards tf64.  Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev, That wardroom is fantastic  Well done you  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 22/07/2012 Posts: 69 Points: 144 Location: Belgium
That detail... , this is really the bomb in modelling! Great craftswork!
Hi Shipmates, A long time since the last post,well I have finish the middle deck planking,but the stairs I found that in my case the wood suplied to week to model with,the only way was to make a copy of the stairs in hard wood. The pictures will show how I copyed the stairs.      Thanks for looking. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 Hi tf64 nice work on the stairs,strange how sometimes supplied parts are useless for the intended application regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, Thanks for looking. Best Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Shipmates, The picture in my last post shows the Companion ways and Ladders.As you can see I had a small problem with the ladders,but I cannot understand the look of the long brass eyebolts,is this how it was,I cannot find ref to it.So I have decided to make my own using 2mm dowel,with the blank I turned to shape,drilled,and stained,although this project in not completed yet I have posted a few pictures.  2mm Blank.  Turning to Shape.  Drilling rope holes.  Size 10mm 2mm.  Fitting wire to base.  Drilling grating. A brown thread will be spun onto 0.50 wire and insterted into each hole. Thanks for your time. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev Beautiful work  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Trev. Absolutly stunning   . Thanks for showing how it was done. Best regards my friend. Mark
A great enhancement Trev
