Hi Iam on issue 17. Do i have to supply the pins for the build Ruppy 13
Hi Ruppy13..Welcome to the forum...And no, you will get the pins (nails) in with your future issue.. Hope this helps....Happy building...
Just checked the official build diary and you should have received a small bag of nails with Issue 17?Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
if you are short i have bags handbags of the things as i removed my pins and reused However you should get all you need so hang fire first. J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
