14 Pages <12345>»
sandnesspeats Options
Maldbuild
#41 Posted : 25 May 2012 22:29:40
Great build so far , I agree with the others pull out the pins . I second planked my build using Walnut and Lime , I then equally spaced pins along the planks approx every second rib ,Gives of a good result without going over the top on a model of this scale.
Happy building
MaldBigGrin
alantait
#42 Posted : 26 May 2012 09:21:39
shes looking very ship shape mate, i agree with the other remove the pins, i left pins in my chinese junk model and now with more experience it looks bad, wish the forum had been around when i started modelling
current builds
sandnesspeats
#43 Posted : 26 May 2012 09:38:19
thank-you all for your inputBigGrin BigGrin .I will sit out in the sunshine and pull them out.it will take a while.
I read in earlier magazines or the forums that you can leave them in to look more authentic when painted or varnished (rivets),but I thought how do you sand the hull with the pins inConfused Confused,`cos metal and wood does not sand the same,must of been putting them back in after sanding or I misread it,anyway they are coming out this weekend.
Thanks again
Cool Cool Cool
z8000783
#44 Posted : 26 May 2012 09:50:44
Groups: Unapproved
To say nothing of the size of the rivets on a 1:80 scale.
Great job BTW, should sand up nicely.
John
sandnesspeats
#45 Posted : 03 June 2012 09:57:55
Hi all,
I am just about to measure the distance of the last 10 planks needed to finish the hull planking (issue 38).The distance id 52mm on rib 21,
would it be advisable to put another plank on to make it 47mm or just work it out from where I am which will be 11 planks.
any help would be great.Wink
sandnesspeats attached the following image(s):
z8000783
#46 Posted : 03 June 2012 10:08:14
Groups: Unapproved
Although it measures up to be more I never found it a problem since there will always be a slight spacing between the planks no matter how tight you make them. It should come down after a couple of planks are laid.
You might find this useful also - Last 10
John
sandnesspeats
#47 Posted : 03 June 2012 11:07:16
BigGrin BigGrin
Thanks for that I have downloaded the spreadsheet, great help.Here goes the measuring!!!
z8000783
#48 Posted : 03 June 2012 11:16:23
Groups: Unapproved
BTW you may still need some droppers and steelers in there.
John
StefanDV
#49 Posted : 04 June 2012 08:47:05
Are you painting your model?
I decided upfront that I was going to paint, so I added 2 rows of planks next to the keel before starting the measuring. I believe it made the process faster and easier.
pierre50
#50 Posted : 07 June 2012 15:50:15
LOOKING GOOD! KEEP THE PICS COMING!
Current Buid:
HMS Victory
Next Build:
Captain Cook's Endeavour Collecting issues
Wish List:
Santa Ana
Bounty
Santisima-Trinidad
sandnesspeats
#51 Posted : 23 June 2012 20:41:19
Hi all sorry for not replying,been very busy.
I have not decided about paint or varnish yet,just concentrating on getting the hull finished,but probably will paint as I bought them ages ago.
Enclosed are some pics just not sure how to proceed.
The measurement at the stern is only 20mm and the middle of the keel to plank is 45mm.
I have never put a dropper in yet anywhere but it looks like I will have to now,Any advice would be greatly appreciatedBigGrin BigGrin BigGrin
farrabass
#52 Posted : 24 June 2012 11:20:58
A quick look through some members build diaries will throw up some options for you!
Darren has produced a graphic in his diary showing how and where to taper the planks to get a snug fit. If painting is going to be your desired finish, then the planking will be covered in paint and will obscure the run of the planks, that will make it easier to blend in some smaller odd shaped filler pieces.
Take your time and have a good read at what is on offer.
All the best Steve..
Sietsemk
#53 Posted : 25 June 2012 16:43:22
I agree, wood filler little bit of sanding and paint problem solved.
The thing is, if you going to build an another model and you want the planking
to be visible, don’t you think it’s a good idée to practice on the Victory while
you are busy with the planking. Only a suggestion.
Your build looks very goodThumpUp.
Built
Albatross, build in 1982 from plans.
Hms Bounty, build in 1987 from plans.
Duyfken,build in 1991 from plans
Oosterland, build in 1998 from plans
In the meantime.
HMS Victory (Deagostini)
2011 Building MFV63 fishing trawler from plans.
HMS Mayflower (Kit)
Wish list
Still planning.
sandnesspeats
#54 Posted : 25 June 2012 17:02:58
Thanks guys,
was trying to find darren to no avail,could you point me in the right direction!,thanks
Just don`t want to be stuck on the same thing for ages,gets tedious.
but will horse on as they say, I will be happy and relieved when the hull is finishedMellow Mellow Mellow.I will get thereBigGrin BigGrin
StefanDV
#55 Posted : 25 June 2012 17:24:13
Darron = Son of Bulwark
sandnesspeats
#56 Posted : 22 July 2012 21:28:38
Hi guys,
I am at a tricky bit,the thing is the stern measures 17.6mm,the widest part is 42mm that is about 8 planks,will I have to reduce the very stern plank to just over 2mm instead of 2.5mm.Confused Confused
Any advice or pointers would be greatBigGrin BigGrin
z8000783
#57 Posted : 23 July 2012 12:53:58
Groups: Unapproved
You need some droppers. The instructions should have already covered these already.
Have a look here (scroll down).
John
sandnesspeats
#58 Posted : 23 July 2012 13:02:08
Thanks John,I thought there might have been another way as I have not put any droppers in yet. But looks as if I will have to.
Thanks again
BigGrin
z8000783
#59 Posted : 23 July 2012 13:04:46
Groups: Unapproved
Have another read through the instruction to check. It does say you may need to use droppers and/or steelers even on the last 10.
John
sandnesspeats
#60 Posted : 21 September 2012 21:17:07
BigGrin BigGrin
Hi all,
Would you look at the pictures and advise me what to do next, I am running out of space before I finish the hull.Do I just keep going as I am and sort it out near the finish or do I try and sort it out now. I have been on this for ages and would like to get it finished,(the hull I mean)
as usual any help would be great.
thanks
14 Pages <12345>»
This page was generated in 0.231 seconds.
