chainwale Options
#1 Posted : 28 May 2012 11:05:26
In issue 75...page 12 paragraph 1, it states for the small chainwale measure 135mm back from the front edge of bulwark...is this correct, because when I measured this out and marked it, it came out 5mm aft of the upper rear-most gun port? Can you shed any light on this one shipmates? Thanks
Confused
#2 Posted : 28 May 2012 11:32:41
Position as per the step 2 photo, or if you have issue 87, then steps 5/6 on page 13 provide a placed view.
This page was generated in 0.576 seconds.
