Twisted hull Options
Mr.Quist
#1 Posted : 01 June 2012 16:11:38
Hi guys,
during the setup of my quarterdeck I realized that maybe my hull is twisted. The mast dowels seem to be straight. beggar.
What would you do except asking MacGyver ???
Cheers, Timm
My build diary here
HMS Victory
Son of Bulwark
#2 Posted : 01 June 2012 17:00:54
Hi Timm! Cool
I'm sorry to see this mate! but it might not be the hull that is twisted. The alignment of the mast holes in the decks might not be true, this would push the mast over to one side making the hull look twisted.
You could adjust the holes in the lower and middle deck on the side the mast is leaning towards using a small round file to straighten the mast, just take care not to enlarge the top hole in the quarter deck.
Darron
harty
#3 Posted : 01 June 2012 18:31:40
If the mast fits in to a slot of some discription, you might be able to shave the bottom of the mast so it goes over and staightens up or shave it up to the offending deck holeConfused
#4 Posted : 01 June 2012 19:28:32
I agree with Darren the holes might be out as he says and Hartys method is another way forwrd if you dont want to ruin your decking
Mr.Quist
#5 Posted : 01 June 2012 19:50:56
Hi Darron and harty,
thanks for the kind words and hints.
Son of Bulwark wrote:
Hi Timm! Cool
Darron
I am afraid it is, at least in parts really the hull, when checking just with the eyes. Haven't got one of these fancy laser thingies.
Also found out that one of the masts isn't straight too, might get a new one.
I will try what you proposed and keep you posted. Hopefully it will not show up too much in the end.
@Andy: The quarterdeck can't be ruined at the moment, the plywood you see right now will be covered with walnut veneer when everything is fixed.
Cheers, Timm
My build diary here
HMS Victory
Blue_Joe
#6 Posted : 01 June 2012 20:00:33
I had the same issues of the deck holes not lining up quite right pusing the past over slightly!
This page was generated in 0.041 seconds.
