56 Pages «<3334353637>»
MWG build diary of the mighty Hood Options
#681 Posted : 01 June 2012 18:09:02
Hi Mark thank you for your kind commentsBigGrin it is appreciatedBigGrin Kind regards MikeCool
#682 Posted : 06 June 2012 15:33:58
ISSUE 40
Hi Team, this has turned out to be a tricky build this week, as I feel Hachette have added a little extra without explaining it in the instructions, I will explain soon.
This is what we received this week;-
#683 Posted : 06 June 2012 15:44:08
ISSUE 40
This is the wallcovering we received this week:-
#684 Posted : 06 June 2012 15:49:55
ISSUE 40
I cut the parts from the fret filed off the burrs as usual, I then bent the parts using the edge of a conti board, as per the instructions:-
#685 Posted : 06 June 2012 15:53:50
ISSUE 40
Then I came to fit the parts, and the part was longer than the wood it was designed to fit.
I looked at the photos in the instructions, and then I spotted what I think is an added infill, take a look:-
#686 Posted : 06 June 2012 15:57:31
ISSUE 40
But no where does it tell you to fit this item, so I used a piece of second planking because the infill needed to be 1mm thick here are the photos of my work:-
#687 Posted : 06 June 2012 16:08:29
ISSUE 40
And the final photos, I do feel someone somewhere has not added the insructions on how to include the infillConfused Questions and comments welcome as usualBigGrin Regards Mike
Jesus-Belzheim
#688 Posted : 06 June 2012 16:51:22
Hi Mike
Veni Vidi... and solved it
Good job ThumpUp
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#689 Posted : 06 June 2012 17:03:02
Looking good mike.
With the bulkheads she starting to look like a ship. Are you looking forward to the paint spraying. I fpound that was the easyest way to do my bismarck. Ian Cool
mark 2
#690 Posted : 06 June 2012 20:04:45
MWG wrote:
ISSUE 40
Hi Mike.
I see what you mean Confused .
I think that someone at hatchette was on the sherry that night LOL .
When i get to that i may wait awhile and see what the next few partworks bring although i think you might be right. I also think that there is anouther wall that leads of that.
This one will be on my next delivery.
Best of luck and regards to you Mike.
#691 Posted : 07 June 2012 11:09:36
Jesus-Belzheim wrote:
Hi Mike
Good job ThumpUp
Thank you PeterBigGrin Regards Mike
#692 Posted : 07 June 2012 11:11:31
ian smith wrote:
Looking good mike.
Hi Ian yes the spray option will be the best but first white squadron puttyBigGrin Regards Mike
#693 Posted : 07 June 2012 11:14:07
mark 2 wrote:
MWG wrote:
ISSUE 40
Hi Mike.
Hi Mark it does appear a bit of a lotteryBigGrin But I am sure it is nothing we can not handle eh?Huh Regards Mike
#694 Posted : 13 June 2012 12:05:36
ISSUE 41
Hi Team this week we have a break from Brass wall covering, and this is what we received:-
#695 Posted : 13 June 2012 12:45:52
ISSUE 41
We put the Brass part away untill another time.
I cut out the wooden parts, and went to assemble them as per the instructions but I found a few challenges and had to trim the parts to fit how the instructions called for, you will see I had to trim a piece of wood off the spacers with the tongue:-
#696 Posted : 13 June 2012 12:56:39
ISSUE 41
But all is well in the end.
I do feel Hachette are putting us through an IQ test with these instructions, sometimes I feel they think we should know what is coming nextBlink Questions and comments welcome.
Mike
Yutaro HONMA
#697 Posted : 13 June 2012 13:28:31
Hi Mike!BigGrin
You've done good job!Love I think this type model is like puzzle, too.Cool
By the way I also think Japanese HMS VICTORY modelers are happy to be able to refer to ModelSpace. Because they can know what parts will come next all 120 weeks.
Best Regards,
Yutaro
#698 Posted : 13 June 2012 18:48:25
Yutaro HONMA wrote:
Hi Mike!BigGrin
Best Regards,
Yutaro
Thank you Yutaro san for nice commentBigGrin you are right about the puzzle.
I am glad the Modellers in Japan refer to the Modelspace, we are very lucky to have such a great bunch of members who are very knowledgable
Best regards Mike
#699 Posted : 20 June 2012 18:09:00
ISSUE 42
Hi Team this week we continue with the wallcovering, but this time using very thin ply (1mm)This is what we received:-
#700 Posted : 20 June 2012 18:11:50
ISSUE 42
Taking the parts I cut them from the fret and prepared them as per the instructions:-
Guest (14)
This page was generated in 0.525 seconds.
