Joined: 10/04/2010 Posts: 28 Points: 70 Location: cheltenham
 hi ship mates just done the anchor what do you think
Joined: 17/03/2010 Posts: 127 Points: 329 Location: cornwall/portsmouth uk
i dont know! i can only see a red cross in a box!! any idea how to get rid of it?? and get the picture
got it now! nice one, i was being a computer biff!
Joined: 30/03/2010 Posts: 285 Points: 880 Location: Belton, Norfolk
Looking good timebob looking good What thickness is the rope you've used??
I wish I were a glow worm, A glow worm's never glum, 'Cause how can you be grumpy? When the sun shines out ya bum!!
2.50mm but i might change it, looks a bit big
Cheers timebob, the reason why I ask is I'm gonna change the rope that was sent in with the anchor to the very one you've used but I wondered if 2.5mm would either be big enough or to big and to be honest after seeing yours I'm still not sure
after pudding the anchor ring you got a job getting rope through. it will only go through the ring once.
Actually  I've just had a look at an anchor which is on the victory now. Now, I know it is a replica anchor but the dimensions should be roughly the same, yes?, and assuming they are it looks like the ring is to small and not the rope being to big!!
i see what you mean it is a fair old ring!!
looking at the anchor in the pic the ring they give us is too small compaired too the size of the anchor.
Take a look at this one too.....  Ring definately looks bigger.
Joined: 22/03/2010 Posts: 236 Points: 709 Location: Falkirk
timebob wrote: hi ship mates just done the anchor what do you think Good work Regards,
David
Joined: 25/03/2010 Posts: 472 Points: 1,357 Location: Hyde
Hi there Great job with the anchor. What kind of rope is it and where can I get it from? Thanks Tom
Joined: 25/03/2010 Posts: 100 Points: 289 Location: derby
Hi It looks really good. I need to get mind going Pam
rope is 2.50mm from cornwallmodels www.cornwallmodelboats.co.uk
I think the rope thickness is pretty good, but the ring as you say is a little too small, Ive just compared your anchor and rope to longridges (picture taken a few years back), maybe you could fashion some thin'ish wire to make the ring bigger?
Great job Timebob,thanks for shareing it with us MWG MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 30/03/2010 Posts: 66 Points: 191 Location: Britannia
AFter puddening the original ring I also discovered the ring was too small. I used McKays Anatomy of Victory to compare the ring size and made a new larger ring out of copper wire. I will post pics in my build thread.
Excellent macmedal, I would be interested to see those as I am gonna do the same thing
Here is a picture of the difference in ring size compared to the original ring after I took it off. Macmedal attached the following image(s):
Guest (6)
