Box Section Options
riff-raff
#1 Posted : 14 June 2012 21:51:53
Anyone out there know where I might be able to find 15x15mm Wood Box Section?
I have looked in the places that I know (which are limitedBlink ) but no luck.
Thanks Guys
Riff-Raff
Built:
#2 Posted : 14 June 2012 21:57:46
riff-raff
#3 Posted : 15 June 2012 13:54:18
I mean has in hollow box section Mr T.
If I can't find any I will have to use plasticard but I can't seem to find that either larger than 9mmx9mm
Built:
#4 Posted : 15 June 2012 14:46:34
You might be lucky enough to find as aluminum or brass section
Dontshootme
#5 Posted : 15 June 2012 14:46:45
Never heard of wooden box section before,would imagine it would be nigh on impossible to manufacture.Could you not try 2 L sections together?Obviously there would need to be a degree of trimming to get correct dimensions but it should be achievable.
RussG
#6 Posted : 18 June 2012 00:35:11
Hi I take it its to line the gun ports, I used plasticard, but im painting and got 12 x 12 from ebay!
If you want to go with wood especially if you are varnishing, you will need:
1x 10x10
2x 10x2
4x 7x2
All available via Mr T's link.
Using 2mm lime strip, the trick is to wrap the 10x10 in cling film then glue your box up, so the glue wont stick to the 10x10 , cut in place then push the center out!!
follow the picture attached,
Hope this helps.BigGrin
RussG attached the following image(s):
Happy Building, Russ
#7 Posted : 18 June 2012 09:01:12
You could probably buy the 10 by 10 at B and Q or any good diy store in there mouldings section
This page was generated in 0.443 seconds.
