Joined: 09/05/2011 Posts: 78 Points: 236 Location: N.Ireland
Found a place for the P.C.B under the seat but still cant decide on place for battery and switch.9v battery required so it'll be 3 button batteries in series.Might seat them behind head rest but ill wait and see.
Joined: 31/08/2011 Posts: 629 Points: 1,963 Location: Plymouth
Hi Davy good stuff  Reards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 20/12/2011 Posts: 134 Points: 384 Location: barnoldswick
it looks good iv got 1 to put on mine but im going to ue a 9v square battery so it will last longer thinking of making a battery compartment under my stand with a switch at the back
Joined: 27/06/2011 Posts: 80 Points: 232 Location: High Wycombe
firefighter wrote:it looks good iv got 1 to put on mine but im going to ue a 9v square battery so it will last longer thinking of making a battery compartment under my stand with a switch at the back i don't think you can just wire up an LED to a 9v Battery, it will just burn the LED out.
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,829 Points: 17,639 Location: ipswich
You can get 9v LED's from Squires electronics, or just wire a resistor in between the LED and the switch. Roy.
Hello all. Its a flashing LED with speed adjust available from maplins electronics.9V square battery will power but the size of it may be a problem if you want all electronics to be kept inside.You will have to build the circuit by soldering.The components required come in a kit.Price approx £7.
