IF ONLY!! IF ONLY!! If only you could have had this brilliant idea two weeks ago when I was fiddling around trying to bend my wire around drill bits and using more than a few expletives trying to get this fiddly little job done Well done there for another clever little work around, I'll bear this one in mind for my next build. Thanks for sharing that & happy building David
 Rank: Pro  Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Looks great Jonny. What is the purpose of the dowel?
Hi Stefan...the Purpose of the dowel is to form the shape of the deadey, wrap the wire round it once, cross the wire then slip the deadeye in and finish the twist with pliers... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Excellent idea - thanks mate!
Another excellent building tip. Thank you Johnny Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Gonna try that, good call.
