22 Pages «<1617181920>»
Stefan's build Options
StefanDV
#341 Posted : 28 June 2012 10:23:23
Thanks Castos!
I'm not going to bore you guys with daily photos of the progress on the tiles, but here is the tiling of the keel on the Starboard side up to the stem.
From what I've seen, the tiling on the keel going to be quite time-consuming, as you only get to lay 1 layer of full tiles on each side. The lowest level has to be trimmed down, and the 2 rows of tiles fitted to the bottom of the keel also must be trimmed. Lots of work for little coverage.
#342 Posted : 04 July 2012 15:34:25
Great Start steffan. Look forward to seeing some more pictures of your progress. Ian Cool
Glen
#343 Posted : 04 July 2012 18:52:51
Hi Stefan,
If you can get Frog Tape out there that will do the job better then masking tape,like your build though.BigGrin
Roger the Cabin Boy
StefanDV
#344 Posted : 05 July 2012 09:58:53
Thanks Ian, it's slow going at the moment. BigGrin
Thanks Glen, I'll have a look to see if I can get frog tape. Have never heard about it though.
pierre50
#345 Posted : 06 July 2012 09:34:58
Hi Stefan
Looking good
Pierre
Current Buid:
HMS Victory
Next Build:
Captain Cook's Endeavour Collecting issues
Wish List:
Santa Ana
Bounty
Santisima-Trinidad
Sietsemk
#346 Posted : 10 July 2012 13:12:40
WOW!!!! Good luck with the tilling Stefan, I’m shore when it’s finished you will open a bottle bubblyLaugh
Built
Albatross, build in 1982 from plans.
Hms Bounty, build in 1987 from plans.
Duyfken,build in 1991 from plans
Oosterland, build in 1998 from plans
In the meantime.
HMS Victory (Deagostini)
2011 Building MFV63 fishing trawler from plans.
HMS Mayflower (Kit)
Wish list
Still planning.
Castos
#347 Posted : 11 July 2012 08:14:57
Well done on the prgress so far and the patience that is being displayed when it comes to tiling.
Current Build: HMS Victory
Built: HMS Bounty
Next Build: Sovereign of the Seas Started collecting. Redrawing of plans for Santisima Trinidad for a scratchbuild. Santisima Trinidad - waiting for launch.
#348 Posted : 11 July 2012 08:41:21
Hi Stefan keep up the good workBigGrin it will be worth it. Regards Mike
#349 Posted : 25 July 2012 16:00:20
hi staffan.
how is your tiling going. look forward to seeimg some more pictures ian.
#350 Posted : 25 July 2012 22:41:17
BigGrin Coming along nicely StefanCool
StefanDV
#351 Posted : 26 July 2012 08:41:43
Hi Andy and Ian,
Things are progressing very slowly, I've been otherwise occupied and haven't touched the Victory for almost 3 weeks! Sad
StefanDV
#352 Posted : 01 August 2012 10:26:23
It's been about 4 weeks since I've last laid a hand on her, but here are 2 pics of my progress over the last 2 evenings:
Tiling the starboard side keel:
Laying down a couple of rows of tiles on the starboard side
I've had no luck with cutting the tiles with a knife, so I'm using scissors.
#353 Posted : 01 August 2012 13:25:43
Looks great
StefanDV
#354 Posted : 02 August 2012 08:54:40
#355 Posted : 02 August 2012 14:11:24
looking good steffan. keep up the good work. what glue did you decide to use on the tiles. IanBigGrin
Bameraam
#356 Posted : 02 August 2012 19:32:24
I'm still baffeled with the paint job! Way well done, nice straight lines on that curved baby LOL
Jesus-Belzheim
#357 Posted : 03 August 2012 17:50:56
The start is looking good Stefan ThumpUp
I hope you use glue without solvent
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
StefanDV
#358 Posted : 06 August 2012 10:17:40
Thanks Gentlemen!
@Ian: I'm swapping between superglue gel, and this silicone type glue
@ Bameraam: Thanks so much - it was a bit of a job getting them "Right" - quite a bit of overpainting, re-masking, touching up and repeat. I would have preferred a fold-out plan as per the masts, but I suppose one has to make do with what's provided.
@ Peter: Thanks! I've tested the glue and it seems to hold quite well, but with enough force, the tiles do come off. Huh
Finished off the starboard stem over the weekend. I'm quite pleased - it feels like I'm getting the hang of working with the copper tiles.
The tiling of the Port-side stem is almost complete, the little triangle gaps must be filled with off-cuts and then all needs to be sanded flush.
I've also laid down a couple more rows on the starboard side.
z8000783
#359 Posted : 06 August 2012 10:20:41
Groups: Unapproved
WOW, you're just ahead of me now, I must catch up.
Nice job.
John
farrabass
#360 Posted : 06 August 2012 15:20:21
Coming along nicely!
The tiling gets a bit tedious at times, but the end result is all that counts. Keep going the way you are, and all will be well.
Steve..
This page was generated in 0.179 seconds.
