Plans/Schnell boot Options
#1 Posted : 14 July 2012 10:13:03
BigGrin Hi im thinking of building a scratch build of an e-boat/schnell boot around a metre long, just wondering if any one knows of a good scale plan they could recomend for the above
Monty's Double
#2 Posted : 14 July 2012 10:37:37
Hello Andy,
Just a thought here, but if you can't find any commercially produced plans for your Eboat/Schnellboot, then maybe you could just buy one of the plastic kits - I think Airfix do a 1:72 scale model - and using a set of calipers and other measuring tools, take measurements at various points along the hull to give the shape of any ribs or formers and then scale them up to whatever size you want and draw them out yourself? The same could be done with any other parts that you need to replicate. Not sure how daft that sounds or if there is a better way, but it might work if you can't get plans?
All the best,
Bernie
#3 Posted : 14 July 2012 10:48:02
Hi Andy,
Models by Design make a 1/24 scale GRP hull and also have a plan set which they may sell separately.
Hull: 57.25"
Beam: 8.25"
http://www.modelsbydesign.co.uk/model_boats.aspx
Battlecraft do some nice fittings..
http://www.battlecrafts.co.uk/
This link might to the sole survivor might useful..
http://www.rovcom.co.uk/s130_ww2_schnellboot.htm
Squadron Signal publications "Warships 18" contains plans and colour plates
http://www.prinzeugen.com/Squadron.htm
#4 Posted : 14 July 2012 11:02:58
BigGrin Thanks for the replys guys the resin hull looks good but was hoping for a more traditional build type plan but still food for thought
thanks again
#5 Posted : 14 July 2012 11:06:24
This superb plastc kit version might be useful
http://www.italeri.com/s...ria=31&idCategoria=6
#6 Posted : 14 July 2012 11:19:54
BigGrin Hmmmmmmmmmmm i had looked at the Itelera kit before a bit pricy but with whats included [etch ect] still a good dealDrool ,I think il need to do some costing as the resin hull and fittings will come to a lot more pricewise i think, desisions, desisionsConfusedLOL
Monty's Double
#7 Posted : 14 July 2012 11:27:40
Hello Andy,
Just been snooping on the internet and I found this E-boat plan. It is at the length you want and self build construction. Thumbnail picture doesn't show exactly what you get in the plans regarding rib/former shapes, etc, but I think there are probably more pages than are shown. Also, it appears to be a 1:32 scale plan which is great as you can buy all sorts of aftermarket stuff at that scale, such as figures, fittings, weapons, etc. I reckon it could be useful to you as it's perfect for scratchbuilding and it's cheap too. Might be worth a punt maybe?:
http://www.myhobbystore....duct/16884/e-boat-mm667
Also found an interesting website for a build of the Robbe S-130 Schnellboot, might be useful for details?:
http://www.modelboatmayh...k/Builds/S130/1ndex.htm
and some useful links to other info about German Schnellboots from the same site:
http://www.modelboatmayh...Builds/S130/Part_15.htm
Hope that helps?
All the best,
Bernie.
#8 Posted : 14 July 2012 16:03:00
BigGrin Thanks Bernie for those sitesCool
Monty's Double
#9 Posted : 14 July 2012 19:06:51
My pleasure Andy, I hope you found them useful.
Bernie.
harty
#10 Posted : 15 July 2012 11:29:13
Hi guys is this the one that you are thinking of building. this one is in 1/35 scale and built straight from the box.
harty
#11 Posted : 15 July 2012 11:30:15
harty
#12 Posted : 15 July 2012 11:31:49
It would look a lot better in the hands of an expert and superdetailedBigGrin
harty
#13 Posted : 15 July 2012 11:32:52
#14 Posted : 15 July 2012 17:51:15
BigGrin Very nice Harty,i think il be using the kit route as the resin hull option is more for radio control and i want a static model.although there is some etch in the kit i have sourced some other etch for the kit aswell
Monty's Double
#15 Posted : 15 July 2012 17:57:35
A very nice build Harty, looks like you have done a superb job there and I love the weathering and worn look. It would look great in a dockside diorama? Well done and thanks for sharing.
All the best,
Bernie.
Monty's Double
#16 Posted : 15 July 2012 17:59:30
Hello Andy,
Sounds very interesting and looks like it will be a very detailed model! I will look forward to watching your build.
All the best,
Bernie.
#17 Posted : 15 July 2012 18:27:11
BigGrin Hi Bernie
thanks for the reply but im hinting[to her indoorsLOL ] its going to be a birthday pressy around october time so it might be a while before i start a diary
This page was generated in 0.135 seconds.
