10 Pages «<78910>
Sean's HMS hood Options
S2ksean
#161 Posted : 22 July 2012 22:17:57
Thanks andy il have a look and see what I can find
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#162 Posted : 22 July 2012 22:28:09
Haven't updated in a while couse of work commitments. I'm up to date on issues but behind on build progress which is not a major problem. Anyway I've had a day off today and managed to get some done
And this is my hedgehog lol
I've done as mike has advised and against the mag completing one side of hood.
As always comments welcome
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#163 Posted : 22 July 2012 23:01:41
Hi Sean
Great Job, very nice workBigGrin Kind regards Mike
S2ksean
#164 Posted : 23 July 2012 00:20:07
Cheers mike it will let a lot better once the pins are out
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
farrabass
#165 Posted : 24 July 2012 00:13:40
Very accurate work with the etch parts you have there!
I have just become a convert to etched extras since I dabbled into the plastic market again after a break of many years. Nice to see the etch following your build like a shadow, keep it up, all the best, Steve..
S2ksean
#166 Posted : 24 July 2012 07:39:30
Thanks Steve I'm hoping to get some more done tonight after work
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#167 Posted : 25 July 2012 11:41:06
Just picked up the latest issue and we got a gun turret and some more etch stuff. Can't wait ta get home and crack. Il post more pics later
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#168 Posted : 28 July 2012 02:15:17
Finally I've finished planking the hull. It's not the best job in the world but it's my first wooden ship and I'm quiet pleased with it. Hopefully look a lot better once it's filled and sanded.
As u can probably see I've not used normal planking pins instead I used dressmaker pins this is because they are very thin and u don't have to pre drill the planks to put them on plus they don't split the wood. The only down side is that when u plank into ply it tends to bend the pins which once again is no prob as these are very cheap. Also I planked the the hull differently to the book and mike way. No real reason for this just thought I'd be different lol
Comment as always welcome
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#169 Posted : 28 July 2012 09:47:00
BigGrin Hi Sean
nice job on the planking and we all have a favorite way of doing it,the pins well i used them for years and like you say dont split the wood [well rarelyLOL ]just a sore thumb to contend with from pushing them home.A word of warning/advice here if your thinking of using spray putty theres a cheap brand doing the rounds,i cant remember the brand, might be silver something as iv dumped the can but heres a discription, grey plastic cap with an overall yellow printed background paper [that cheap paper/printing the chinese are so good atBlink ]and its a grey colour when sprayed.The fumes from this stuff is lethal unless your using an industrial spray booth and breather system.
S2ksean
#170 Posted : 28 July 2012 13:19:12
Thanks for the comments and advice andy. Il be using ronseal wood filler although I'm not sure which primer I should use for painting?
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#171 Posted : 28 July 2012 13:34:40
The ronseal filler works a treat and sands very easily as for undercoats/fillerprimers[spray putty] well any good brand will do iv been using halfords own brand lately.TBH any good undercoat is ok its coverage your after,you probably already know this but a good idea is to undercoat the hull and then sand it all off this will highlight any places to be filled [if any] and any high/low spots.Hope this helps
S2ksean
#172 Posted : 28 July 2012 14:44:36
Cheers andy. I've taken out the pins and giving her a very very light sanding. Here's how she looks. You'll notice the the planking pattern I've used and to be honest was a bit of a pain the arse to do when ya got to the last planks
There are a couple of gaps that im not happy with but I'm hopefully the filler will sort it. Overall Im reasonably happy with it do far
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
willie
#173 Posted : 28 July 2012 15:10:15
dressmakers pins were used well before the fancey model making pins were on the go and you can get stronger ones that are harder to bend all you need for pussing them in is a dress maker thimble as said dont worrie about small gaps a lot of us gets them i use ronseal filler for mine natural pine sands about the same rate as the wood we are using
S2ksean
#174 Posted : 28 July 2012 15:19:59
This is the filler I got. Is it right?
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#175 Posted : 28 July 2012 16:04:24
BigGrin Hi Sean
The hull looks sweet,the filller you have got should be fine but the one most of us talk about on here is the one pictured below.Its a 2 part filler like car filler and goes off in 10 minutes or so sandable after 30 mins apx.A good tip when using it is to mix very small amounts as it goes off suddenly in 1 go and work it into any blemishes by applying from left to right then right to left to make sure the hole is fully filled.Hope this helps
S2ksean
#176 Posted : 28 July 2012 20:01:00
Thanks andy.
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#177 Posted : 04 August 2012 10:47:23
Look what I got peeps
I've got 20 of them. Now all I need to done is work out the best way to hook them up any suggestions????????
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
daffy09
#178 Posted : 05 August 2012 14:35:30
Regarding your lighting, why not have a look at Bamaaram's Victory build diary, he has done an amazing job fitting miniature lights and it looks like he has experience in this field, and could be the man to answer your questions. There are others but this was the build I was looking at most recently.
Happy building
David
P.S. I'm not actually building HMS Hood - I'm just following the build diaries out of a family interest in the ship herself. My work is cut out with the Victory build which I am way behind on at presentBigGrin
S2ksean
#179 Posted : 24 August 2012 18:37:03
Had a chance to do a little more work today
Turret and range finder glued as per instructions. The blast bags and barrols are not glued in placed
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#180 Posted : 24 August 2012 19:14:32
Hi Sean, good jobBigGrin Regards Mike
Guest (6)
10 Pages «<78910>
This page was generated in 0.884 seconds.
