Building Mikes a binnacle. Options
#1 Posted : 29 July 2012 17:10:16
For those of you who have invested in Mikes upgrade... this is my binnacle build.
The Binnacle comes in 4 parts 3 etch and 1 laser cut wood. Its a massive improvement on the one supplied in the kit, still I have upgraded it a little!!BigGrin
The Binnacle is actually hollow so I decided to remove the two supports in the centre
next I painted the inner facing parts white. while the paint was drying I cut two pieces of clear asertate sheet the same side as the etch faces.
next i carefully painted the black aroung the glass frame so i would not have to do this after construction. once dry the five parts where sandwiched together with some super glue and left in a vice to set.
Once dry I filed the edges smooth and glued the top on. make sure you do this countersink facing down to give you a flat top. when dry I drilled a small hole part way through the top for the chimney. the binnacle is painted black and the chimney added (this will be painted copper later). i am sure you will agre a significant improvement
Thanks mike Cool BigGrin
#2 Posted : 29 July 2012 17:35:00
What...no navigational instruments within LOLLaugh
Serously, its looks a great enhancement and well done Jase Cool
#3 Posted : 29 July 2012 22:16:58
Hi Jase,well done BigGrin nice to see it completedLove Kind regards Mike
mark 2
#4 Posted : 30 July 2012 07:13:18
Hi jase.
That looks fantastic.
Great work.
Best regards.
This page was generated in 0.038 seconds.
