urgent help required please asap Options
firefighter
#1 Posted : 02 August 2012 11:29:03
Iv just started putting the left rear fairing fence and the left flip up together when i test the parts by holding them in place before glueing iv got a 3mm gap is this right if not how do i loose it to help everyone understand iv added a pic so you can all see to give me any advise
only1ianuk
#2 Posted : 02 August 2012 11:38:09
Hi,
There is meant to be a gap! If you check the official build diary it shows a gap between the 2 parts!
Check post 3 and see if its the same as yours?
http://forum.model-space...aspx?g=posts&t=4271
Ta
Ian
#3 Posted : 02 August 2012 11:42:28
The gap is correct and meant to be.
firefighter
#4 Posted : 02 August 2012 12:44:50
thankyou i was getting little bit conerned i had messed up great i can carry on with my build
