8 Pages <1234>»
Harty,s Royal Caroline new build Options
harty
#21 Posted : 02 August 2012 18:00:32
Hi Andy, what you see is what you get and I have,nt ordered any extras. I may get the sails later on or make them myself which I have done in the past. The brass looks a bit garish but I will tone it down with the brass to black and buff it up. Gun carraiges are a bit oooah so I will replace them with the spare from the Surprise build as they are almost the same scale and look betterBigGrin
#22 Posted : 02 August 2012 18:33:06
BigGrin sweeeeeeeeeeeeeeet
I did have the feeling that the enhancments available were for those who just bought the plans[apart from the sails]and yes after looking on the link to the build and how he improved the metal bits, after a little weathering they definatly look better.One thing to look out for is the burrs [if there are any] as too often there left on and guilded overAngryi could never see the point of this.
I presume the gun carriages suplied are of the cast metal type and as you say can always be improved upon or discarded for a better type,good luck with the build il look forward to your diary.
catman275
#23 Posted : 02 August 2012 21:42:49
Hi Harty,
The rear decoration you have is laser cut wood. Mine is photo etch brass.
The brass castings are in a different style package.
My gun carriages are wood I think yours are as well I don't know how well they will go together, we will have to wait and see.
The brass strips I have, have been bent to get them to fit in the box and do look a bit of a mess.
I was looking for eyelets in the kit, couldn't find any, then realised that is what the pintles are there for.
Apart from the laser cut wood it looks the same.
cheers Peter
completed..... Endeavour Longboat, San Francisco 2, Virginia 1819
building Royal Caroline
harty
#24 Posted : 05 August 2012 11:09:01
Well here we go again. This is just a dry fit run of all the bulkheads and decking, just to make sure all are ok. They are,nt too bad as it happens. Then take it all apart and do the shaping on the bulkheads to take the planks.
harty
#25 Posted : 05 August 2012 11:11:22
First layer of planking going on and that will be as far as they go until decking has been done and any extra detail.
harty
#26 Posted : 05 August 2012 11:12:44
Nearly ready to start laying planks.BigGrin
Ger C
#27 Posted : 05 August 2012 12:28:07
She's looking good
zebedeee
#28 Posted : 05 August 2012 13:53:34
BigGrin Zooming along there Harty looking good (as expected)
How do you find fairing the frames before fitting them to the keel?
#29 Posted : 05 August 2012 16:14:56
BigGrin looking like a good start thereCool
harty
#30 Posted : 05 August 2012 16:45:22
Hi Zeb, I think it is definately easier fairing them down before glueing. You begin to get a feel for the hull after doing a few and it is not too bad if you only have to make little adjustments when planking, the worst of it is gone thenBigGrin
harty
#31 Posted : 05 August 2012 16:51:30
Hi Andy, this is definately a tricky little build and all the picture main plans are in ItalianCrying , so it is not for the faint hearted. I think mistakes will be made on this oneBigGrin , just have to cross that bridge when ever. I dont want to start cutting all the upper planking to the template until I am positive its good.
harty
#32 Posted : 05 August 2012 17:17:57
Decking going in.
catman275
#33 Posted : 05 August 2012 19:01:59
Hi Harty,
What is the size of your decking strips?
Mine have been supplied at 3x0.5mm. Yours look as if they are 1.5 or 2mm.
Cheers Peter
harty
#34 Posted : 05 August 2012 19:41:35
Hi there Peter, the decking is 2mm. It is the same as on my Surprise build, all left overs. It goes together better and looks better I think specially when treated with the danish oil. You have just got to be a bit wary of the increased height ie gunport clearance for the cannonBigGrin
#35 Posted : 06 August 2012 09:38:14
That's a very nice build there Harty...Like it!! Wink ThumpUp
harty
#36 Posted : 06 August 2012 15:07:03
Thanks very much Johnny,been concentrating on decking in the past couple of days, got as far as thisBigGrin
harty
#37 Posted : 06 August 2012 15:08:47
Only just got this one done, poop deck next then all the hatches I thinkBigGrin
farrabass
#38 Posted : 06 August 2012 15:14:39
Very nice! a good tidy build you have there.
Steve..
catman275
#39 Posted : 06 August 2012 21:56:49
She's looking good Harty
You will have that finished before I have got my box open.
Only kidding.
Due to me waiting on some parts for my Virginia 1819 I have made a dry fitting on the RC.
I have fitted the frames and decks but noticed that the mast holes don't line up. The foremast leans forward instead of vertical but the others follow the plans.
Also the fore upper deck supports are different heights.
did you notice anything like that in your build?
cheers Peter
harty
#40 Posted : 06 August 2012 22:13:18
Hi Pete, yeh I had those but I just put it together and filed it all down to a happy medium. The joys of model makingLaugh .
8 Pages <1234>»
This page was generated in 0.281 seconds.
